that's very good, nothing to worry about.
4790k @ 4.6 (1.25 adaptive) // 2x GTX 970 stock clocks/voltage // Dominator Platnium 4x4 16G //Maximus Formula VII // WD Black1TB + 128GB 850 PRO // RM1000 // NZXT H440 // Razer Blackwidow Ultimate 2013 (MX Blue) // Corsair M95 + Steelseries QCK // Razer Adaro DJ // AOC I2757FH
https://linustechtips.com/topic/311821-fx-6300-oc-temps/#findComment-4238070
yes, anything under 62C is safe
https://linustechtips.com/topic/311821-fx-6300-oc-temps/#findComment-4238071
I'm ocing my fx 6300 and my core maxes out at 55 Celsius and my socket 46 degrees during prime 95 small fft do you guys think m these are safe temps for my 24/7 oc?
Yup, below 62-65C is considered ok for 24/7 OC.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/311821-fx-6300-oc-temps/#findComment-4238072
It look fine to me if 55 is what it maxes at
 The Wannabe is no longer. Replaced by the Flotilla. If you replace every part of a computer is it still the same computer?
Survived the Survivor 2299
Audio Engineer, Lighting Programmer, Video Engineer, FOH.
https://linustechtips.com/topic/311821-fx-6300-oc-temps/#findComment-4238074
