84x is 32 bit?
Go to solution Solved by TheSLSAMG,
Go download x64 and install it? x86 is 32-bit.
I am downloading windows 10 and I clicked on the us English and clicked 84x and it was a 32 bit how do I get a 64 I need it for the games. Do not whant to buy windows 8.1/7
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
https://linustechtips.com/topic/309995-84x-is-32-bit/
https://linustechtips.com/topic/309995-84x-is-32-bit/#findComment-4214395
Yes, "86X" is 32 Bit. But don't use 32BIT anymore, 64 bit is the way to go.
I would go for Windows 8.1 as, it's more like Windows 10 than Windows 7 is.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/309995-84x-is-32-bit/#findComment-4214396
Sorry I clicken the 86 i thought it was 84 do not know y
https://linustechtips.com/topic/309995-84x-is-32-bit/#findComment-4214407
Ok you would think the higher number is 64 bit but whatever
https://linustechtips.com/topic/309995-84x-is-32-bit/#findComment-4214415
Ok firstly DO NOT use Windows 10 as your main OS... its not finished and will be buggy and due to the agreements you sign you will be tracked for purposes of bug tracking.
But as said above 86=32 64=64
Windows 10 is REALLY stable for a beta.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/309995-84x-is-32-bit/#findComment-4214441
But the fact is its a Beta. Meaning the security is not as best as it could be :( that bothers me but I guess its ok for some people.
The difference is marginal, TBH.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/309995-84x-is-32-bit/#findComment-4214462
