212 EVO
https://linustechtips.com/topic/309478-temporary-fan/#findComment-4206622
Water cooling as in closed loop or custom loop?
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
https://linustechtips.com/topic/309478-temporary-fan/#findComment-4206655
Where are you shopping/located?
https://linustechtips.com/topic/309478-temporary-fan/#findComment-4206678
Custom loop
And I'm located in southern California, next to Disneyland
The Pure Rock performs similarly to the 212 Evo but is quieter: http://pcpartpicker.com/part/be-quiet-cpu-cooler-bk009
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/309478-temporary-fan/#findComment-4206885
So I want to get into water cooling but it's not in my budget for another month or so. Need something that will cool my i7 5820k in the mean time. Something from frys or micro center. Under $100
@WoodenMarker ;)
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/309478-temporary-fan/#findComment-4209174
Ahh, if in case the OP can only shop from Fry's or Microcenter, I'd suggest something like an ETS-T40: http://www.frys.com/product/6826996?site=sr:SEARCH:MAIN_RSLT_PG
https://linustechtips.com/topic/309478-temporary-fan/#findComment-4215298
