So I have a I7-4790K, Noctua DH-15, and Asus Z97-A motherboard.
I am wanting to overclock my processor.
I watched another video explaining how to do so and failed with a blue screen so here I am.
Any tips? I am a complete noob. Should I just let Dual Intelligent Processors 5 do the overclocking for me since it came with the mobo? Or should I do it by myself in the bios. Thanks, anything helps!
https://linustechtips.com/topic/308297-overclock-help/
Increase the clock baby steps at a time.
When stability drops, increase the voltage (again, baby steps)
Rinse and repeat until you get where you want to be.
And in case I didn't say it... BABY STEPS, OP!
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/308297-overclock-help/#findComment-4189979
Blue screens are part of overclocking, it doesn't mean you failed. Simply increase the voltage until you get stable results or temps get too high, in which case you'll need to decrease the multiplier. Also make sure to carefully follow an overclocking guide, not just some youtube clip.
https://linustechtips.com/topic/308297-overclock-help/#findComment-4189999
Don't use over 1.35V core voltage. You should get at least 4.7GHz with 1.27V. That seems to be average for that chip. But remember that every chip is different.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/308297-overclock-help/#findComment-4193281
The youtube clip I watched was from ASUS. Im still kinda afraid to overclock the last two times has resulted in blue screen on startup.
https://linustechtips.com/topic/308297-overclock-help/#findComment-4195628
just increase the voltage don't be afraid . if for example your got a blue screen on 1.200v make it 1.210 on next restart then 1.220 on next if not stable .
Also Press F6 in Bios and put your CPU fans on manual then drag 3 dots on 60 on 40C 80% on 50 C and 100C on 60C and save the setting .
CPU: i7 4790K | Ram:Corsair Vengeance 8GB | GPU: Asus R9 270 | Cooling :Corsair H100i | Storage : Intel SSD, Seagate HDDs | PSU : Corsair VS 550 | Case: CM HAF Advanced.
https://linustechtips.com/topic/308297-overclock-help/#findComment-4195653
don't worry, bluescreens on startup don't damage your PC, it just means your overclock isn't stable. You're going to see a lot of bluescreens while overclocking, its completely normal. As I said, a detailed overclocking guide is always better than a youtube clip, even if its from ASUS. Just take your time and go step by step, overclocking is free performance, but you still have to work for it.
https://linustechtips.com/topic/308297-overclock-help/#findComment-4196320
i was too, its fine, like that guy sad, baby steps, increase Clock by 0.1 ghz if blue screen, increase voltage
My windows wanted to restore to default once lol
        Sample Text ( ͡° ͜ʖ ͡°)
https://linustechtips.com/topic/308297-overclock-help/#findComment-4196536
I've got the same mobo, and CPU (except I'm using the Dark Rock Pro 3 by Be Quiet!).
I'm interested in your results...Please share when you reach the breaking point.  ;)
Well I've got mine to 4.7Ghz on core 1 and 2 and on core 3 and 4 I have 4.6Ghz since I did per core to get more out of the overclock. I am sitting at around 1.36 volts.(Not sure if I want to keep it this high) Max temps reach around 82c with idle at around 31c
https://linustechtips.com/topic/308297-overclock-help/#findComment-4205135
I haven't OC'd yet.
Might fiddle with the clock timings this weekend...  :ph34r:
https://linustechtips.com/topic/308297-overclock-help/#findComment-4205638
i did 3 times windows restore and 2 time CMOS clear from 4.5ghz till 5ghz . and it took me 3 days to stablize every step 4.5 then 4.6 then 4.7 ...5.0ghz .
https://linustechtips.com/topic/308297-overclock-help/#findComment-4205936
