Hello.
I am shopping for a mechanical keyboard. Can you please help me? I cant decide between red and brown switches. I need the keyboard for gaming but i am looking for something that is simillar to my current roccat isku keyboard. Which switch color is more similar to my current keyboard?
Thank you for replying.
https://linustechtips.com/topic/308164-cherry-mx-problem/
Its all really up to personal Preference. If you like having tactile feedback and type alot go with browns. reds are really smooth and easy to press quickly.
both switched really aren't like your current keyboard at all because you have a membrane keyboard.
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
https://linustechtips.com/topic/308164-cherry-mx-problem/#findComment-4188053
I use my Cherry MX Reds for gaming and some typing, they do the job. I would prefer blues but they're just too dang loud for me even with dampeners.
Browns are a mix of both, you may like them.
Workstation i7-3930k | GTX 980 SLI | 2 x P2715Q (2160p) | AX1200i | H100i
Server E3-1245v3 | 24GB RAM | Be Quiet! 600W PSU | Be Quiet! Rock Pro 3
https://linustechtips.com/topic/308164-cherry-mx-problem/#findComment-4188059
But which is more simillar?
https://linustechtips.com/topic/308164-cherry-mx-problem/#findComment-4188063
do you feel a small bump going down ? or a ''gliding'' slide , smooth decent ?
https://linustechtips.com/topic/308164-cherry-mx-problem/#findComment-4188123
yes i feel very little bump
the go for browns. thats what I have. and I love them
https://linustechtips.com/topic/308164-cherry-mx-problem/#findComment-4188214
@STRMfrmXMN did a good page and quizz on key switches which may help you out.
look here -> http://linustechtips.com/main/topic/255051-what-key-switch-should-i-get-look-here/
Hello.
Also remember to follow your own topics
https://linustechtips.com/topic/308164-cherry-mx-problem/#findComment-4188217
I just was in this perdicament and decided to opt for the Browns. I think the initial "click" will be confidence inspiring and the force is just slightly higher than Reds.
Sometimes i troll...
3D Mark Fire Strike Score: http://www.3dmark.com/fs/3854240 +215mhz Core Clock +440mhz Memory Clock @4.6ghz 1.325v
http://pcpartpicker.com/user/b1aze/saved/qQFxFT
https://linustechtips.com/topic/308164-cherry-mx-problem/#findComment-4192341
