usb to audio jack
Go to solution Solved by MRL,
Okay you want a usb sound card
no he doesn't
his headphone is using USB interface, and right now he wants to use his headphone on his mobile phone using 3.5mm audio jack
and as far as I can tell, there's no way you can do that. USB headphones acts like a USB sound card/DAC. As far as my electronics engineering knowledge goes, it is much easier for you to find a new pair of headphone that does 3.5mm rather than converting it.
a year back i bought a headphones called zebronic iron head but i only bought it for pc
now i need to turn the usb in a audio jack so i can connect to my mobile phone
pls send me the link where i can buy
If that actually works, your headphones might need the power the USB gives (and possibly won't be given by the 3.5mm port)
https://linustechtips.com/topic/307844-usb-to-audio-jack/#findComment-4183431
I dont know, I just posted the first thing that came up on ebay :D never used such a thing before... USB headset/headphones suck, imho
https://linustechtips.com/topic/307844-usb-to-audio-jack/#findComment-4183440
It's easier on PC, since it is just 1 port. You sometimes have compatibility issue with mobile devices, but you are pretty guaranteed it will work on consoles, PC, Mac etc (devices with USB ports)
https://linustechtips.com/topic/307844-usb-to-audio-jack/#findComment-4183447
I know, I just prefer analog vs digital :D
https://linustechtips.com/topic/307844-usb-to-audio-jack/#findComment-4183468
mine is samsung galaxy s4 and iphone 6plus
i need comparability for both
i want it from usb to  AUX Audio Plug Jack not the other way around
Qoute people when answering them, that way they get notified of your post.
Either way, I am not sure if it would be compatible (as I said earlier). Look at some of the reviews or questions of the product probably.
https://linustechtips.com/topic/307844-usb-to-audio-jack/#findComment-4183629
no he doesn't
Gadgets: Lenovo Y580 (Nostromo, Naga Epic, Hydra, TrackIr5), Surface Pro 3 (i3), Lumia 930, PSVita
Rig: i7-4770K, 8GB Kingston HyperX, Asus Strix GTX970, MSI Z87-GD65, Asus Xonar DGX, CMStorm Scout II, CM Seidon 240M, BlackWidow Ultimate, Naga Epic, Goliathus Extended Control, TrackIr5, Sennheiser HD205, Audio-Technica ATR2500, Edifier speaker, Logitech G940, Logitech G27, Logitech F710, Dell S2340L, Philips 200VL, Samsung 830 128GB SSD, DXRacer FA01N
https://linustechtips.com/topic/307844-usb-to-audio-jack/#findComment-4184982
why do they suck ???
My friend own the MS live chat 3000 and they are great.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/307844-usb-to-audio-jack/#findComment-4185008
basically not going to happen.
https://linustechtips.com/topic/307844-usb-to-audio-jack/#findComment-4185117
My bad, I was not specific. Surround 5.1 and 7.1 via USB suck, because thats only virtual surround, I know from experience. Owned a pair of virtual 7.1 - Genius GX Gaming CAVIMANUS HS-G700V and real 5.1 Roccat Kave :) but that is kinda offtopic here :D
https://linustechtips.com/topic/307844-usb-to-audio-jack/#findComment-4185205
Virtual surround can be good through USB it depends on the headphone, actually USB can be much better at some situations.
  ﷲ   Muslim Member  ﷲ
https://linustechtips.com/topic/307844-usb-to-audio-jack/#findComment-4185241
Long story short: You can't just convert USB to a 3.5mm plug
What you can do is if you're next to your computer, you can bride the output.
Heres a diagram: phone > 3.5MM audio cable > line in > windows with enabled microphone playback on "line in"  > headphones plugged into a USB port.
There might be devices that emulate what the computer would do but I'm not too sure.
https://linustechtips.com/topic/307844-usb-to-audio-jack/#findComment-4185244
That can be true, m8,I was just comparing the two and the Roccats sounded way better :) dont h8,m8, its all gr8 :D
https://linustechtips.com/topic/307844-usb-to-audio-jack/#findComment-4185294
When a headset is plugged in using USB, you are bypassing the audio on your PC (usually on board) which certainly with older hardware, is a good thing. It will be a better sound card which is built into the headset over what is on an older PC. Nowadays, it's less of a problem. I actually like this because when you plug the headset in, Windows will default to that device and remember any settings you've chosen for it, when you unplug it, the devices will go back to how they were before. Nice.
To say they suck, why? I don't have a USB headset as such, but I do have an amp on my desk which connects to my PC for when I want to use speakers, then, I have an Asus Xonar U3 USB sound card for my headphone amplifier. I have to manually switch devices in Windows for this which is a fair sight more convenient than having to have a load of analogue cables daisy chained together.
https://linustechtips.com/topic/307844-usb-to-audio-jack/#findComment-4185337
Thanks m8 I appric8 I r8 8/8.
  ﷲ   Muslim Member  ﷲ
https://linustechtips.com/topic/307844-usb-to-audio-jack/#findComment-4185398
Sound card ?? It's called a DAC "Digital Analog Convertor".
  ﷲ   Muslim Member  ﷲ
https://linustechtips.com/topic/307844-usb-to-audio-jack/#findComment-4185412
All sound cards have DACs. A USB headset will incorporate a USB sound card.
By definition sound cards are installed in your PC and headphone DACs aren't installed in your PC, there is no sound card in a headphone.
  ﷲ   Muslim Member  ﷲ
https://linustechtips.com/topic/307844-usb-to-audio-jack/#findComment-4185515
