I am upgrading my system and getting a windowed case. I want to add some nice lighting effects to the case. Either red or blue. I am leaning towards red since it is easier on the eyes. What case fan would you suggest? I'm getting an nzxt s340. I was looking at the corsair af120 but wasn't sure if there was a cheaper fan that has good lighting. Not going for performance or silence, simply pretty lights.
01101100 01110110 01101100 00100000 00110101 00100000 01101101 01100001 01100111 01101001 01101011 01100001 01110010 01110000
https://linustechtips.com/topic/307114-best-led-fans/
corsair and bitfenix have nice LED fans
https://linustechtips.com/topic/307114-best-led-fans/#findComment-4172716
maybe check out some case lighting products instead - this will give a more evenly lit appearance, or can focus on only those pieces you want highlighted.
Define R5 Black Window || i5 4690K || Scythe Kotetsu || Asus Maximus VII Gene || Kingston Fury 8GB || EVGA GTX 980 Superclocked ACX 2.0 || EVGA G2 750W || SSD/HDD/ODD
https://linustechtips.com/topic/307114-best-led-fans/#findComment-4172719
dont get led fans
get led strips :D
What LED strips would you suggest? I was looking into those and was thinking bitfenix alchemy.
I was thinking the bitfenix fans.
https://linustechtips.com/topic/307114-best-led-fans/#findComment-4172737
yes those are great
https://linustechtips.com/topic/307114-best-led-fans/#findComment-4172767
Would 12cm be enough you think??
if you can fit 140s, go with 140s
https://linustechtips.com/topic/307114-best-led-fans/#findComment-4172834
