Using OpenCL to use iGPU for non-graphic activities
Solved by msvelev,
This thread belongs in the programming subforum.
Programming using the OpenCL API will enable you to use the GPU for non graphic tasks so you can use it to do heavily paralleled computing on the GPU instead of the CPU and get much faster programs.
This paragraph only states that you can use the iGPU the same way you could use a discrete GPU.
EDIT: What programming language do you use? Most languages would have a library which will give you access to the OpenCL API.
Featured Topics
Mark Kaine ·
Posted in Displays0 -
1
1
tippytipper ·
Posted in Storage Devices1 -
2
AlyShazli ·
Posted in New Builds and Planning18 -
4
Emmanuel Katto ·
Posted in Peripherals3 -
3
4
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
