The right CPU cooler
Go to solution Solved by Faceman,
So my Intel Core i7-4790k is getting some way too high temps just from gaming (~85 degrees C) because I have the stock cooler installed. I want to overclock it and have it run cooler, so I'm thinking maybe the Corsair Hydro H100i or maybe the Enermax LiqTech 240. Which one of those will perform best? Is it correct that they don't need for me to maintain them or change the liquid? Any other suggestions? Thank you
Avoid the H100i, mounting problems and noise issues.
I recommend the Cooler Master Nepton 240M because it is low price, and has an excellent blend of low noise and high performance without having to change out the fans.
Case: Antec Twelve Hundred V3 | Motherboard: ASUS Maximus VII Hero | CPU: Intel Core i7-4790k @ 4.4GHz | RAM: G. Skill RipjawsX DDR3-2133 MHz C9 QC - 16GB | GPU: GIGABYTE GeForce GTX 980 G1 Gaming | PSU: Corsair AX860 | SSD: 2x Samsung 840 EVO SSD's in RAID 0
https://linustechtips.com/topic/304456-the-right-cpu-cooler/
Look at the new H110i GT. It'll be a beast in cooling and it just came out.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/304456-the-right-cpu-cooler/#findComment-4137839
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/304456-the-right-cpu-cooler/#findComment-4137840
I forgot to mention that it's in an Antec 1200 v3, so it can only be 120mm x2. Unfortunately not those 140mm's.
https://linustechtips.com/topic/304456-the-right-cpu-cooler/#findComment-4137891
The Nepton 240M looks good, I'm considering to buy it right now
CPU: i5-6600k @ 4.4GHz | Motherboard: Asus Z170 Pro Gaming | RAM: 8GB HyperX Fury | GPU: Asus Strix GTX 980 | Case: NZXT Noctis 450 Red/Black | Storage: 256GB Sandisk SSD + 1TB Western Digital HDD | PSU: EVGA 750w | Monitor: ASUS VS247H | CPU Cooler: Cooler Master Hyper 212 Evo | Keyboard: $15 Cheapo Rubber Dome Keyboard | Mouse: Rosewill RGM-300
Linus Tech Tips Pebble (and Pebble Time) notifier watchface!
https://linustechtips.com/topic/304456-the-right-cpu-cooler/#findComment-4137906
I would get a nice dual air-cooler if it will fit. Phanteks has a nice one; it is in quite a few colors and performs just under a noctua nh-d15 which is better than basically any AIO.
https://linustechtips.com/topic/304456-the-right-cpu-cooler/#findComment-4137951
Ok you'll need a 95 Honda civic a sump pump some garden hose a refrigerator and a lot of duct tape. Or maybe a Nepton 240 although the nh-d15 is a good option aswell
I am the one who goes bump in the night... usually making a sandwich.
Case: Phanteks Enthoo Primo White - Motherboard: ASUS X99 Deluxe - CPU: Intel i7 5820k - RAM: 4x4GB Corsair Vengeance 2666mhz ddr4 - GPU: Dual EVGA gtx 980 SSC - PSU: EVGA G2 Supernova 750w - Cooler: Custom PETG Loop on cpu and gpus - Storage: 500gb Samsung 850 evo ssd, 2x Seagate Barracuda 7200rpm 3tb hdd
https://linustechtips.com/topic/304456-the-right-cpu-cooler/#findComment-4138004
