My tax returns are larger than normal. (thanks obama) And i'm going to replace the K702's I had for years that my ex accidentally broke. It was my fault for leaving them on the back seat not hers. Anyway for some reason the akg website doesn't list specs on the 701's. They're Amazon pricing is fairly close but the 702's are about 40 dollars cheaper at the lowest price i can find. I can get the 701's in the Quincy Jones signature with the revamped audio profiles for about 184 and the 702's for about 225. So what's the difference.
https://linustechtips.com/topic/302112-difference-between-k702-and-k701/
They both do.
There are three versions of the K702, the newest of which does not have the bumps.
However, if you're buying within 2 days, might as well get the K7XX off massdrop: https://www.massdrop.com/buy/akg-k7xx-massdrop-first-edition-headphones
I absolutely would if my tax return was here but i likely wont get any money for a week or two so yeah. Can't do that one.
Gotcha. Stupid gubbmint - quick to take your money, slow to give it back.
is the q701 the quincy jones one as opposed to the k701?
Unless you want to pay $50 more on what is essentially a popular anime markup (Miophones beyatch), no reason to go K701.
AD2000x Review  Fitear To Go! 334 Review
Speakers - KEF LSX
Headphones - Sennheiser HD650, Kumitate Labs KL-Lakh
Actually Optimum Pro Audio has been selling the K702 for $199 for awhile now.  They go out of stock often but at least advertise the flat (no bumps) headband:
http://www.amazon.com/gp/offer-listing/B001RCD2DW/ref=dp_olp_new?ie=UTF8&condition=new
System: i5 6600K@3.6 GHz, Gigabyte Z170XP SLI, 2x8 Corsair DDR 3000, Corsair Hydro H60i cooler, Rosewill CAPSTONE 750w Gold PSU, 1x 512GB SSD, 1x 2TB 7200RPM, Windows 10 Pro x64
Display: XFX R9 390 DD, triple 1920x1200 24" HP monitors (5760x1200 @ 60Hz)   Sound: Audio-gd NFB-11 -> AKG K7XX or 2.1 speaker system
actually if you look close at their image it has the bumps.
The bump in that picture linked is the button which holds the headband to the suspension.
I stand corrected. Are the head bands replaceable these days. Mine weren't but they were old.
God damn that looks sexy
Yes they do. Damn do they. I'll be over here, in the bushes, alone.
Just found this stated on a tech website.
The 702s are identical to the 701s except that the pads on the 02s are thicker which allows a more "around the head" speaker-like experience with regards to soundstage.....The 702s also have a detachable cable and do not come with the little stand that is supplied with the 701s........This pair of headphones is marketed as the studio version of the K701.
