So I recently read about the GTX970 and one of the questions I had was that it says that this issue happens above 3.5gb of vram. The GTX 970 comes with 4gb  of vram but how come most laptops that use a GTX970 comes with only 3gb vra,. Does this mean that these laptops don't have this issue. Thanks for your help and any replies are very appreciate.
https://linustechtips.com/topic/301960-need-clarification-on-gtx970/
LAptops have a 970M and not a 970, a totally different chip so they are unaffected
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
970m is not a 970
The 970M is a completely different design (with regards to layout and the like), and so it doesn't have the issue
Specs: CPU: AMD FX 6300 Motherboard: Gigabyte 970A DS3P RAM: HyperX Fury 16GB 1866MHz GPU: MSI R9 270 OC edition Case: Sharkoon VS3-S SSD: Samsung 840 EVO 120GB HDD: 1TB Caviar Blue PSU: Corsair CX500W
*If I say something that seems offensive, please don't take it seriously, it was most likely meant as a joke/sarcastically*
the 970m has a 192bit memory bus, and can come with 3GB or 6GB of Ram. It's basically what people speculate a 660Ti will be, except the 970m has lower clock speeds to keep temperatures down inside small form factors.
in short, 970m is fine.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
