"Your display driver stopped working and has recovered.""
I was playing battleffield 4 and my screen went a little wonky then I gopt that message.
Is the card overclocked?
Intel i7 3770K [] Asrock Z77 Extreme 4 [] MSI R9 290X 4GB [] 16GB  G.SKILL 2133Mhz [] Crucial MX100 256GB [] WD Black 1TB [] XFX Pro 850W [] Fractal Define R3 [] Func MS-3 R2 [] Corsair K60 []
https://linustechtips.com/topic/301510-gpu-problem/#findComment-4097458
Usually that's the result of an unstable GPU overclock.
Is it sir? Then the he better stabilise it then. :D LOL
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/301510-gpu-problem/#findComment-4097459
Try to resintall drivers.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/301510-gpu-problem/#findComment-4097484
You should be a comedian. Not.
OP, is anything overclocked?
https://linustechtips.com/topic/301510-gpu-problem/#findComment-4097490
You should try and be nice. ;)
https://linustechtips.com/topic/301510-gpu-problem/#findComment-4097528
Now that was funny.
https://linustechtips.com/topic/301510-gpu-problem/#findComment-4098094
No.
Has this occurred multiple times or just once?
https://linustechtips.com/topic/301510-gpu-problem/#findComment-4098097
