Resolution?
https://linustechtips.com/topic/30013-bf4-max-out/#findComment-383483
I have 2 questions:
1) What resolution will you be playing at?
2) Is that a 2GB version of the GTX 680? (I assume yes)
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
https://linustechtips.com/topic/30013-bf4-max-out/#findComment-383492
If it's indeed at 1080p, yes. GTX 760 review for reference: http://www.anandtech.com/show/7103/nvidia-geforce-gtx-760-review/10
There's a 670 in there. Slightly less powerful than a 680. Link is to the Battlefield 3 FPS page.
https://linustechtips.com/topic/30013-bf4-max-out/#findComment-383500
BF3 pushes the 7970 OC - So BF4 you will expect to be far more demanding.
It's dependent on your setup, resolution & current system specs.
You would hope a SLI 680 system would perform well, but we really never know.
Look at Crysis 3 :o
Akula  | Dimastech Test Bench | Watercooled | Tri GTX 680's | Build of the Week
Mercury | Caselabs Mercury S3 | Watercooled | GTX Titan | Build of the Week
Armada | Define R4 Titanium | Watercooled | EK Waterblocks | Newest Buildlog
https://linustechtips.com/topic/30013-bf4-max-out/#findComment-383502
I would guess it should be fine, but a constant 120fps is not guaranteed since i've seen videos of people having a GTX 690 getting 100 fps at MAX in BF3. (85-95 whilst recording)
Intel i7-2600K @ 4,5GHz | EVGA GeForce GTX 780 w/EKWB Copper Waterblock | Kingston HyperX blu 16GB @ 1600 MHz | Phanteks Enthoo Primo | MSI Z77A-GD65 | CM M1000 Silent Pro | Samsung 840 Pro 128GB | BenQ XL2420T 120hz | Logitech G710+ | Razer Deathadder 2013 -
- XSPC Raystorm CPU Waterblock | XSPC RX360 Radiator | EKWB EK-FC Titan GPU Waterblock -
https://linustechtips.com/topic/30013-bf4-max-out/#findComment-383505
At e3 they where running bf3 ultra 1900x1200 with two 7970s(don't know the fps but probably above 60). Two 680s in sli should scale as good if not better .
They we're running vsync (console fps lock)
https://linustechtips.com/topic/30013-bf4-max-out/#findComment-383546
Vsync is on PCs too.
https://linustechtips.com/topic/30013-bf4-max-out/#findComment-383558
Although it's only an ALPHA benchmark, Nvidia cards seem to perform better currently in BF4 - although expect that to change come release, as it's aimed for AMD.
https://linustechtips.com/topic/30013-bf4-max-out/#findComment-383565
Yeah but they we're just showing off how it would look on consoles.
https://linustechtips.com/topic/30013-bf4-max-out/#findComment-383566
I'd imagine it would take about a 770 to get a constant 60fps with the maximum settings and no AA at 1080p. I have no idea what it would take for 120fps though, it also depends on the map, number of players, etc. too.
I get a constant 60fps completely maxed out on a gtx 670.
hello
https://linustechtips.com/topic/30013-bf4-max-out/#findComment-383569
Yeah, i've searched around and 2x680's should give you 70 - 130 FPS in BF3. So i'm sorry i don't think 2 gpu's will give you a constant 120fps unless you lower the settings on the game to get you those 120fps^^
Edit: Actually it's more like up to 180 fps depending on map^^
I know on my 580 i get up to 100 fps on some maps on some area's ^^
Edited by crunzaty
https://linustechtips.com/topic/30013-bf4-max-out/#findComment-383590
Alright so based on what limited info is available for BF4 (e.g. we won't know 100% until it comes out), I would say this:
1080p maxed out via 2x 680 in SLI: Yes
At 120 fps constant: Probably not
Above 60 fps constant: Very likely yes
I'd say you'll get a variable frame-rate between 120-80 or so. It probably will drop below 120 fps often, but will still be pretty high.
If you want 120 fps constant, you're likely looking at 2x GTX 780's or 2x Titan's in SLI.
https://linustechtips.com/topic/30013-bf4-max-out/#findComment-383611
No textures, ignore that benchmark.
AMD Radeon 7870 Gigabyte OC / Intel i5 3570k / ASrock Z77 Pro4 /Samsung 840 EVO 250GB / WD Blue 500GB 7200rpm / Kingston HyperX T1 2x4GB 1600mhz / SeaSonic 520w M12 / Thermaltake v4 Black
https://linustechtips.com/topic/30013-bf4-max-out/#findComment-384033
