Corsair H110 vs NZXT Kraken x61
Solved by airdeano,
the only real differences between the two AIO are the fans. the pump/radiator
are same (NZXT has LED). so within margin of error the two are pretty close.
if you feel you need the softy support the NZXT is there, but for mobo control
either is a best as they are so close to identical. they were made by Asetek to
the client's "specs".
Featured Topics
bluesheep ·
Posted in Troubleshooting0 -
RvG Iced ·
Rogers24 ·
Posted in Troubleshooting3 -
TurkishBTW ·
Posted in Peripherals0 -
1
kennethk ·
Posted in Peripherals1 -
8
