Hi,
I'm trying to get more into photoshop and I'm trying to find out if it's possible to make lines that gradually get wider or bigger... I'm trying to make some lines that move from the back of an image to the front of an image and hopefully make it so they're moving closer to me and I'm using Photoshop...
Does anyone know how I can do this?
I'm extremely new to photoshop...
https://linustechtips.com/topic/298632-photoshop-help-please/
Hi,
As an alternative to what's been previously suggested you could just create a line, Rasterize the shape, Free Transform the line, and then right click it and select Perspective.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/298632-photoshop-help-please/#findComment-4053374
Trying to make something like this?
Well, for that your going to want to use the perspective tool, make the bottom (closest bit) wide (Even wider than the canvas would work) And the top (Bit furthest away from you) skinny
EDIT: To use the perspective tool: control + T, Then right click and perspective
https://linustechtips.com/topic/298632-photoshop-help-please/#findComment-4053437
Thanks for all the suggestions, just figuring out what I can do.
Not exactly, something for a project. Thought it might be a cool design.
Not exactly sure what I'm doing.
https://linustechtips.com/topic/298632-photoshop-help-please/#findComment-4053467
if u can make a sketch of what u want to do, i  can tell u how u can do that thing.
https://linustechtips.com/topic/298632-photoshop-help-please/#findComment-4054140
