No one can really tell when or if it is going to be fixed however it really only affects performance at high resolutions like 4k. 1080p and 1440p will be perfectly fine and not bottlenecked.
[-] i7 4790k @ 4.7ghz [-] Asus Maximus VII Formula [-] EVGA Gtx 980 Sc [-] Corsair H105 [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/TBNRunity/saved/#savedbuild_1797964
Honestly, 3.5 GB Vram is perfectly sufficient for the card anyway. Buy away. I still wouldn't hesitate to recommend it. Just because people realized that the card has slightly less usable VRAM doesn't suddenly invalidate all those great benchmarks.
Yo bro, did you know that your "1TB HD" actually only has 9XX~ish GBs of storage? Yet, do you make a fuss about it?
No. Just as no one should make a fuss about this 3.5gb issue (which is poorly exaplined, btw..)
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
This is a poor comparison to the problem. It has always been the case the 1TB drives aren't, or 2TB or whatever drives have ever been in the history of hard drives. It's not the case when your game comes to a crawl because it can't use the RAM it says it has. It's a bug, a flaw, and a problem for those that bought these cards. Don't be an ahole "bro".
CPU - 4790k / GPU - EVGA GTX 980 / Case - NCASE M1 v3 / Board - ASUS Impact VII  / PSU SFX 600w Silverstone / Storage - 2x500GB EVOs / Windows 8.1,OS X 10.10 / Full Water Loop
I think it depends on whether you plan on buying another one to SLI. You are basically buying a 3.5gb card. I'm also more suspicious that the 256 bit bus could be a bigger issue in future titles than some people are willing to admit.
If you have a case with good airflow and a good PSU I would probably opt for a 290x. You have a 512 gb memory bus AND an extra half gig of VRAM, making the card more future proof, and the 290x can usually be found for less than the 970. In some cases its cheaper enough that you can use the extra money saved to buy a better PSU and case for crossfire down the road.
CPU: Ryzen 7 3700x,  MOBO: ASUS TUF X570 Gaming Pro wifi, CPU cooler: Noctua U12a RAM: Gskill Ripjaws V @3600mhz,  GPU: Asus Tuf RTX OC 3080 PSU: Seasonic Focus GX850 CASE: Lian Li Lancool 2 Mesh Storage: 500 GB Inland Premium M.2,  Sandisk Ultra Plus II 256 GB & 120 GB
Actually they should. If it acted like it only had 3.5gb that would be dandy. But no, once you pass that the game goes to shit and you really have no way of making sure it wont pass that unless you have the settings so it doesnt go near even 3gb, which is bs.
Also hdd have "less" space than advertised because HDD manufactures see 1MB as 1000KB. But Windows and other OSes see 1MB as 1024KB. And when you buy a hdd you know its not exactly 1tb, when you buy a 4gb gpu, you expect it to be 4gb.. Not 3.5, not 3.5 and .5 gimped.
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
I have a feeling that you may not be this relaxed about this problem if this was an Amd product.
Main rig. Updated :D CPU: FX8350 @stock Cooler: Corsair h110 Motherboard: Ga-990fxa-ud5 Memory: Corsair Vengance 8Gigs 1866Mhz GPU: MSI GTX 970 SLI (blower cooler)  PSU: Cooler Master Silent pro 850w SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue Case: Thermaltake core V71 Fan controler: NZXT Sentry
Secondary PC: CPU: i5 4670k @stock Cooler: Thermaltake NIC L/31 Motherboard: Asus Z97I-PLUS Memory: Corsair Vengance 8Gigs 2133Mhz GPU: ZOTAC GTX 780 (Titan cooler) PSU: Antec 520m Pro SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue & WD 2TB Green Case: Thermaltake core V1
