Get a non-reference 980. SLI 960's? ewwww
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
A single 970 and then a second one if/when you need more power.
I'd go with the Gigabyte G1 gaming 970 and just block off the blue LED.
One of the biggest things with Maxwell is the huge overclocking headroom, something, which is less existent on a reference cooler/pcb.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
Despite the vram allocation problem, 970 offer u much better performance/dollar.
Get a 980 if you feel like you need the extra performance over the 970.
Intel i7 3770K [] Asrock Z77 Extreme 4 [] MSI R9 290X 4GB [] 16GB  G.SKILL 2133Mhz [] Crucial MX100 256GB [] WD Black 1TB [] XFX Pro 850W [] Fractal Define R3 [] Func MS-3 R2 [] Corsair K60 []
A 980 if you can, I know Galax has a white one.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
i looked at the galax HOF and was going to add it, but its over 600$
Get a Gigabyte 970 and tape over the LED. Done, all black card, and you can use the rest of the components for white accents.
PSU Tier List | CoC
djdwosk, the biggest problem with me is that my case is windowed, so asthices are VERY important to me, and my OCD wants to rip the oddly colored copper pipes
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487088&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
PSU Tier List | CoC
GTX 980 alll the way
i7 4790k | ASUS Z97 Gryphon | 8GB Corsair XMS3 1333Mhz | Asus Direct CUII GTX 770 1267/3829 | Stock Cooler | Antec Neo Eco 520W | WD Green 1TB
Silverstone TJ08-e | Klipsch Promedia 2.1 | Razer Tiamat 2.2 | LG 24EN43VS | Razer Naga (2010) | Razer Lycosa (2010)
Planned PC Upgrades: https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=325661&action=wish_lists
GTX 980, that card is a Beast!
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
