help please
Solved by creatip123,
Its not the cable
Then RMA it is the best option. You could try to fix it up yourself, but that'd definitely void the warranty, and potentially end up with more problems than how it is now.
Issac Zachary ·
Posted in Troubleshooting1 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0 -
6
play_circle_filled
Latest From ShortCircuit:
