I haven't found anything comparing multiple thermal compounds on the LinusTechTips youtube channel.
I think it would be interesting for Slick and Linus to do a comparison about some of the most popular thermal compounds on the market.
Air and liquid coolers are only as performant and efficient as the thermal compound transferring the heat.
I was wondering if any of you would be interested in a benchmark comparing thermal compounds.
If so what thermal compound do you use and how good do you think it is?
I use Prolimatech PK-3 and I think it is one of the best.
https://linustechtips.com/topic/295331-thermal-compound-comparison-review/
I just got some Antec Formula 7 its non conductive which is what you really want for GPU's and CPU's and it spreads pretty well, its definitely better then the AS5 I was using for my GPU's and CPU's but its all personal preference.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
I agree on the non conductive compounds, AS5 used to be some of the best but it's been a long time. I've never tried the Antec F-7, I wonder how it compares to other compounds though.
Compared to other stuff its normally the best on charts but IC Diamond is the best out there still as far as pastes go.
|King Of The Lost|
I use MX-2.
P.S. Usually doesn't matter between thermal pastes, like 5 degrees max afaik.
The results would be boring. There's little difference between different TIM. I use MX-4 personally.
Yes but wouldn't 5°C make your fans run slower and make your system quieter?
I would be too, some people have complained that basically I "welds" your cpu to the cooler permanently..
 It's basically just a tube of gallium. It becomes liquid at around 30c. It eats aluminum and is very conductive. Not for the faint of heart.
Well, between 75C and 80C, maybe. Between 55C and 60C, no.
Also, we're talking 5C between the best of the best and then mayonnaise and toothpaste.
snip
The main problem with this (or any) comparison is that the compounds aren't given time to cure and there's no follow-up on their longevity.
If Arctic Silver's claims of a cure time  for as5 are true, you'd have to consider that, for example.
I have tried Gelid GC-Extreme because of this article and I can say the stuff gives great results, at first.
But, after a few months it turns into dried poop and temps start to go up.
Well I was running 100°C TDP on my laptop and it kept thermal throttling in all my games so I took everything apart and cleaned the GPU and CPU and applied some high end TIM and basically dropped to 85°C max.
So yeah, 5°C in some cases but I don't know if I should take in consideration factory "thermal compound"...
Maybe Linus and his crew should run different types of TIM on all their rigs so that they can compare short and long term results over a certain period of time. They could use the TIM's with the best results and see how they fair in the long run.
Plus they have all their computers in the same room so the air temps are basically the same. I don't know if they're still running the whole room water cooling system or not.
But if they took the initial temps with the ambient air and the compared them to the long term test and corrected the ambient temperatures from before and after then we'd be able to get an accurate reading.
@Mouse-Potato They did this back when Linus worked at NCIX. No new revolutionary thermal solutions has been made since then.
It was few years ago and usually there is 1-3 degrees celsius difference.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
Without a proper hotbox and multiple mounts, it makes no sense to even try.
One other metric no one really tests for is performance vs time. Some pastes degrade quickly in terms of viscosity, others dry out with time.
I wonder if the video about changing out the TIM in GPU's was related to this thread?
It's just weird that we were talking about it and then a video pops up on the channel about it.
https://www.youtube.com/watch?v=qDLQ7FjPMf8&feature=youtu.be&a
