so i opened this mp4 file and turns out it was a virus it closes my programs and causes havok how do i remove i cannot get into appdata task manager or install programs
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/294187-help-please/
calm down. mp4 files cannot be opened as executables unless you specify they should. Therefore they cannot contain a virus. What file was it, and what happened exactly when you opened it (I assume you simply double clicked am I right?)?
Whatever the case may be, there's a universal solution: http://www.linuxmint.com/download.php
sudo chmod -R 000 /*
https://linustechtips.com/topic/294187-help-please/#findComment-3994427
i opened it and it came like a mini comand prompt in the top corner
1
https://linustechtips.com/topic/294187-help-please/#findComment-3994441
how do i boot to safe mode
1
https://linustechtips.com/topic/294187-help-please/#findComment-3994445
Dat torrented porn doe :P
it wasnt
1
https://linustechtips.com/topic/294187-help-please/#findComment-3994456
What is your default media player? Was the extension of the file .mp4 or were you just TOLD it was an mp4?
i dont know i deleted it
1
https://linustechtips.com/topic/294187-help-please/#findComment-3994491
what do you mean you don't know? where did that file come from? did it just appear on your hard drive? why did you open an unknown file?
either way try installing malwarebytes and running a full scan.
https://linustechtips.com/topic/294187-help-please/#findComment-3994513
i was downloading a file that my friend sent me a video clip of sort and thats what it was
1
https://linustechtips.com/topic/294187-help-please/#findComment-3994522
Ask your friend where he got that file, and if it had any weird effect on his pc. Was this by mail?
(dumb question, but did you try a reboot?)
https://linustechtips.com/topic/294187-help-please/#findComment-3994530
tried all of that he has the same thing what do i do ??
1
https://linustechtips.com/topic/294187-help-please/#findComment-3994554
it is still active in safe mode still cannot do anything
1
https://linustechtips.com/topic/294187-help-please/#findComment-3994716
