Gap between fans and radiator?
Solved by Peter Vaughan Truslow,
What if I just have Noctua fans which are known for "tunnel-like" airflow anyway? Or the air will just still escape through the gap?
EDIT: Here is a gasket http://www.umart.com.au/umart1/pro/Products-details.phtml?id=&id2=432&bid=&sid=226687
Should I go for it?
I personally would try just normally and if I felt a lot of air coming out around the perimeter I would then buy the gasket. definitely a good idea but I'm bad at spending money.
if I did it, I would probably put one on each side if that makes sense, especially when the cost is less than the shipping.
