Return it and get a new one.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
It's my second one though, WTF. > :o
It's okay you have a warranty.
  ﷲ   Muslim Member  ﷲ
What does the benchmark in Magician tell you?
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
401 read 383 read
61257 read IOPS 48165 Write IOPS
Yeah... That's not right.
And @CoolaxGaming Really? Yours is that bad too?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
:( Join the club
I FOUND A FIX HOLY FUCK, you need to plug the SSD into PO1 port on the mobo then while its running go to the advanced disk options in the bios and set it as SSD, works fine now 520mb read.
If you want I can elaborate more over skype or teamspeak or something.
PEWDIEPIE DONT CROSS THAT BRIDGE
IOPS is fixed? I dont have advanced disk options, by PO1 you mean SATA port 1 right?
Lets all ripperoni in pepperoni
Yeah PO1 = SATA port 1, yes my IOPS are fixed. Since you have a ASUS board I don't know what to do, I run AsRock.
Well, maybe it is my AMD sta dosent have that many options. Im betting my money on the Maximus VII Formula.
Anyways, good to see you found the fix!
I have. The 4790k and the Formula are literally right next to me... They work, but I am waiting for my custom loop to arrive
Just use the Intel for the mean time and let the H100i dangle.
My last one was faster before it died on me, wth samsung.
It's the size. only with the Samsung 850 series will 120GB perform as good as 240GB and larger. every other current 120GB SSD will not saturate a SATA III bus.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
Guide pls! which is the PO1 port???? i also have bad speeds! 370 read
edit: im on gigabyte Z97X-GAMING 7
        Sample Text ( ͡° ͜ʖ ͡°)
I fixed it m8, 520 mbps write
dafq i just benchmarked and got 500 mb/read and 500 mb/write i dont know hows that O_o
but only 8829 IOPS random write
edit: hmmm maybe because i had activated the "Prefetch / Superfetch" ON and i have all the games on HDD and it doesnt use the SSD,and then it deactivates SSDs write and read ??
