I'd recommend testing it for each scenario, it will take a tiny bit extra time, but it's always different in every situation in my experience thus far with PC's.
Sometimes the top fans need to be in push as an intake through the rad, sometimes exhaust pushing from the bottom, etc.
It's probably best you test it and find out.
https://linustechtips.com/topic/292562-radiator-and-fan/#findComment-3973107
yeah but arent there any ways that it would run cooler and cleaner
https://linustechtips.com/topic/292562-radiator-and-fan/#findComment-3973141
Pull in exhaust (radiators on top of the rad) is fairly easy & should be the simplest to clean and maintain.
https://linustechtips.com/topic/292562-radiator-and-fan/#findComment-3973181
Generally you want fans on top of the case to exhaust since hot air rises. And i'd recommend running the fans in pull for easy cleaning.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
https://linustechtips.com/topic/292562-radiator-and-fan/#findComment-3973190
ok so fans against case pull and radiator down?
Yes. Stacked like this: Radiator - Fans (pulling air) - Case. Most Watercooled builds use the fans on the bottom for looks but its a pain to clean the rad from dust this way.
https://linustechtips.com/topic/292562-radiator-and-fan/#findComment-3973215
Top of case
Fans (taking air from inside of the case and blowing it out)
Radiator
Inside of case
Does this help? :P
https://linustechtips.com/topic/292562-radiator-and-fan/#findComment-3973280
Top of case
Radiator
Inside of case
Does this help? :P
yeah, tahnk you so much :)
https://linustechtips.com/topic/292562-radiator-and-fan/#findComment-3973293
