you just need more intakes than exhaust, usually by one or two fans.
front and bottom should be intake, rear and top should be exhaust.
https://linustechtips.com/topic/292221-air-pressure/#findComment-3969071
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/292221-air-pressure/#findComment-3969073
If by coolers you mean fans, no, you want to have at least one exhaust. Optimally, you want more intake than exhaust as this creates positive pressure.
https://linustechtips.com/topic/292221-air-pressure/#findComment-3969079
No no no no. As I assume you are talking about rads in "coolers" you will have them as outtakes. I will explain like this. As Linus so very well explained in his video, you want a slightly possitive airpressure. So if you have 3 outtakes you want 4 inntakes, 2 outtakes 3 intakes, you get the idea. Those outtakes should be your rad.
You are talking about dust, well your radiator is not a fan filter. Filter your inntakes son! Filter everything. This keeps dust out of you coolers. If you use your rad as a intake you will either have to filter it, causing it to be a lot less efficient, or you will have it filled with dust also causing it to be less efficient. If you have filtered inttakes and your rad as a outtake it will be clean as a wistle.
But wait, there's more! When you use your rad as a intake you will fill your PC with hot air, making every other component warmer (also, that actually increeses the airpressure inside your case). And your GPU is what really needs that cold air, it is presumably aircooled, and it also outputs a lot more heat. Therefore having a 60 degree card, and 50 degree CPU is a lot better than a 90 degree card, and 30 degree CPU.
https://linustechtips.com/topic/292221-air-pressure/#findComment-3969457
Awww sweet :D , I watched the video too before and in short
Slightly higher air pressure in case = more intakes than output
Filter my intakes to prevent dust
ALWAYS filter your intake fan(s)--this is very important no matter how positive the pressure is. The chain is only as strong as its weakest link, so to speak.
https://linustechtips.com/topic/292221-air-pressure/#findComment-3972630
Positive pressure ONLY reduces dust if your intakes are filtered.
Otherwise you will get best temperatures by maximizing exhaust flows at the top and rear of the system, even if that means negative pressure within the chassis.
You'll  just have to de-dust more often.
https://linustechtips.com/topic/292221-air-pressure/#findComment-3976417
