Should be, maybe replace the fans with Noctua in the future, and maybe a Hyper 212 or a BeQuiet cooler instead. Otherwise it's good.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
how about the gpu can i max out minecraft at 1080p and how about csgo 1080p both at about 144 fps and above? how about metal gear solid 5
You should be fine, 144FPS isn't a necessity, but it should run at around that, except maybe MGS5
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
If that computer can't max out minecraft at 1080p, nothing will.
You'll be fine
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
so to get past 144 fps on all of those should i goto a bigger system or should i just order as and i will be fine?
This is good, it's a great system in fact. THe only thing you might miss out on in MGS5 is some AA. Don't worry though.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
http://pcpartpicker.com/p/VGrmBm
need it to be quiet
Add a BeQuiet PSU and it will. :P JK
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
Get a 4690K or else get an H97 board.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
but i want it to be quiet
that has nothing to do with it being quiet.  if you want it to be quiet, get quiet fans.
INTEL i7 4790K | GIGABYTE GA-Z97X GAMING 5 | A-DATA 16GB | PCS+ R9 290 | SAMSUNG 840 EVO | MOMENTUS XT BARRACUDA |  FRACTAL DESIGN R4
need it to be quiet
It should be but as @dadasmithywinkle said, You should probably go for 4690K. Though I'd recommend you get be quiet! Fans and possibly the be quiet! Dark Rock Pro 3.
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
Then get an H97/B85/H81 motherboard. The Z series is only good for overclocking and you dont have an overclocking chip.
need it to be quiet
The Arctic i11 is 130mm tall. The TU100B has a max cpu cooler height of 60mm.
Yes.
will a 4790k benefit me becuase im way under my budget?
Meh, if you want the extra power then get it but don't just spend $100 to spend $100. It'd be better to get a 980 than the 4790K.
http://pcpartpicker.com/p/Rzzk7P
will this be good for multi tasking and play games?
to get that 4.0 ghz do i need to overclock or is it stock 4.0
Stock base speed is 4 GHz. It will automatically increase that to 4.4 GHz as demand warrants and provided it stays within its temperature envelope.
As a very general rule, the faster a cpu runs the more heat it generates. Which means the cpu cooler has to work harder, i.e. the fan has to spin faster. The faster the fan spins, the louder the system.
http://pcpartpicker.com/part/gigabyte-motherboard-gaz97nwifi
Expansion Slots: 1*Mini PCI-E (for 11ac WIFI)
Onboard Video: Depends on CPU
I'm not sure that motherboard supports GPU.
The motherboard does have a x16 PCIe 3.0 slot.
