Shopping for microphone
AT2020 if you can also afford the XLR Mixer. If not the Blue yeti is good aswell
AT2020 sounds warmer than the Blue yeti
@MrSushi
I would go with the USB AT2020
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/290968-shopping-for-microphone/#findComment-3951115
Hello.
Can you reccomend me some good microphone for youtube comentaries and game streaming? Budget is up to 100€.
Thank you very much for replying. :)
Blue Snowball or Yeti are very good choices.
https://linustechtips.com/topic/290968-shopping-for-microphone/#findComment-3951137
Blue Yeti / AT 2020 / Razer Seiren   ???
Thank you for any advice. :)
Definitely not razer
Blue yeti sounds a bit more airy/open
My preference is to go with the warmer mic
https://linustechtips.com/topic/290968-shopping-for-microphone/#findComment-3957785
Does Blue Yeti have more features?
You can change the mic mode (omni, stereo, cardioid and something else
https://linustechtips.com/topic/290968-shopping-for-microphone/#findComment-3957904
