Is 850W psu enough for this build?? and are thermaltake psu's good?? do i take them to account?? I don't want a really expensive one
MSI Z97 GAMING 5 Socket 1150 Motherboard   Intel Core I7-4790K Devil's Canyon Quad-Core 4.0GHz LGA 1150 Desktop Processor   MSI GTX 980 GAMING 4G GDDR5 Kingston HyperX Beast 16GB (2 X 8GB) DDR3 2133MHz CL11 1.6V   Corsair Graphite Series 780T Full Tower PC Case (Black) and is it the best choice?? cause i'm not getting extra fans   Western Digital (WD) Caviar Black WD1002FAEX-00Z3A0 1TB 64MB cache   Samsung 840 EVO Series 2.5 Inch 250GB SATA III TLC Internal Solid State Drive (SSD)   Corsair Hydro Series H110 280mm Extreme Performance Liquid CPU Cooler   so is this thing enough??  and is thermaltake a good choiceThermaltake Smart m850w PSU
https://linustechtips.com/topic/290394-help/
Do you plan on doing SLI? 850W for one GTX 980(even overclocked) is a complete waste of money. Hell, 850W for two overclocked 980s is a waste. Also, which unit are you looking at?
https://linustechtips.com/topic/290394-help/#findComment-3943101
Is 850W psu enough for this build?? Yes. A system with an i5 and 980 can also be powered on a quality ~500w unit.
and are thermaltake psu's good?? Depends on the unit
do i take them to account?? What do you mean? Should you take Thermaltake into account when buying a PSU? Sure. If the store you are buying from has a good quality PSU at the right price, then yes, you should considered it along with your other options. Of course, the only way for us to tell you if it is worth it is to know what is available to you at what price point, and as such, we need to know where you are buying from.
The Thermaltake Smart M SP-850M is a good mainstream unit. Can you provide a budget for the PSU and links to where you are able to buy from?
https://linustechtips.com/topic/290394-help/#findComment-3943188
MSI Z97 GAMING 5
Intel Core I7-4790K
Western Digital (WD) Caviar Black 1TB
Samsung 840 EVO Series 250GB
Slightly better formatting.
500-550W is enough. If you're planning SLI then 750W would do the trick for that. 850W is fine though, overkill though, and likely over priced for what you actually need.
As for the ThermalTake Smart M 850W, it's nothing special, but isn't a bad unit. Apparently it's kinda loud though. But since you're planning on keeping the stock case fans, it's not like you're going to have a quiet system.
How much is your PSU budget? How much is the cost of the ThermalTake unit for you? We might be able to find a better and/or lower cost alternative.
Make sure to include currency, location, and if possible your preferred retailers website.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/290394-help/#findComment-3943264
My budget is 1200 egyptian pounds it can go higher for a better performance and a safe one the thermaltake is 1100 I prefer nothing sp plz help
https://linustechtips.com/topic/290394-help/#findComment-3945677
@quan289 advice was spot on.
when the community makes suggestions, they are usually one to watch out for
best budget planning.
https://linustechtips.com/topic/290394-help/#findComment-3945781
https://linustechtips.com/topic/290394-help/#findComment-3945837
http://www.egprices.com/en/product/seasonic-m12ii-750w-evo-edition-750-watt-80-plus-bronze-full-modular-psu-el-nekhely-technology
http://www.egprices.com/en/product/seasonic-m12ii-620w-evo-edition-620-watt-80-plus-bronze-full-modular-psu-el-nekhely-technology
http://www.egprices.com/en/product/seasonic-s12ii-bronze-520w-80-plus-certified-psu-el-nekhely-technology (If not planning SLI, this is the one I'd buy. Though it's not modular. The M12's above are modular, higher wattage versions)
EDIT: Modular version: http://www.egprices.com/en/product/seasonic-m12ii-620w-evo-edition-620-watt-80-plus-bronze-full-modular-psu-maximum-hardware
http://www.egprices.com/en/product/evga-supernova-750-b2-bronze-psu-el-nekhely-technology
The retailer for the units above doesn't seem to have a website, though they appear to have a physical store in Cairo.
so which of these is better in terms of performance/ silence / and heat  and would be enough if i overclock
 - Thermaltake EVO Blue 2.0 850W Up To 950W 80 Plus Gold Modular (evo-850mpcgeu-a)
-  Thermaltake Toughpower Grand 850W 80 Plus Gold PSU
-Thermaltake Smart m850w PSU
-EVGA SuperNOVA 850 G2 Gold PSU
-Cooler Master Silent Pro M2 850W Plus Silver PSU
and is 850w enough for the build up there??? will it be enough if i overclock??? will it be enough if i get 2 gtx 980s which is not likely to happen cause the 1000w are really expensive :D
https://linustechtips.com/topic/290394-help/#findComment-3947646
The EVGA Supernova 850w G2 is the best out of all of them.
And yes, a 850w PSU is more than plenty for an OCed i5 and two 980s in SLI.
https://linustechtips.com/topic/290394-help/#findComment-3959984
