I need a subwoofer! Suggestions?
Enstage
Currently my setup in terms of sound is:
Computer > Scarlett 2i2 > KRK Rokit 5's
I want to insert a subwoofer between the Scarlett and KRK's, my price range is about $100-$300.
I live in Australia if it helps!
Thanks
KRK makes a good companion sub for the rokits.
http://www.sweetwater.com/store/detail/KRK10S?adpos=1o1&creative=54989476081&device=c&matchtype=&network=g&gclid=CNHdhMSfkMMCFQuQaQodbGoAOQ
surf around for a cheaper one, don't be afraid to go used
CPU - Intel Core i7 3770K @ 4.60GHz 1.264v | RAM - Corsair Dominator Platinum 16.0GB (2x8GB) | Motherboard - ASUS P8Z77 WS | Graphics - EVGA NVIDIA GeForce GTX 960 | Storage -  120 GB Samsung 840 EVO | PSU - Corsair RM650 | Case - Corsair 550D
Yes, but as I mentioned, my price range is $100-$300 not $800.
the link he posted was for a $400 sub that was on sale... not $800
I purely said $800 from memory, sorry if I was unclear. My price range sadly still sits at $100-$300.
And it's about $800 when you include shipping to Australia...
you could build one for somewhat cheap... i just build one that cost me about 200 in total. do you have access to a table saw?
Yea I do. I'll do some research on it.
What parts do you think would be the best?
You'll want a 10" cone at the smallest, some plywood, a plastic port tube and a cheap matching amplifier with a crossover. You can get pretty much everything at partsexpress.com
time and patience saves a lot of money ;)
Indeed, thanks very much! I'll give it a try and hop there is no magic smoke.
I can show you the designs of mine if you'd like!
It might be a bit different then what you might need though
But be sure to simulate the enclosure first. Slapping a random driver in a random enclosure is a recipe for a bad sounding sub
I need bass ._.
Sure, go ahead if you're willing :D
Thanks!
Thanks! I'll make sure I do, after looking up what you mean... hehe
Speakers have electromechanical parameters, called Thiele Small Parameters (TSP for short).
With help of the TSP you can simulate the performance using a simulator like WinISD.
You need at least Qts, Vas and Fs.
After you loaded the parameters in the simming program you can play with the box and see what impact your changes will have.
