I have a i7 980x
With 8gb of ram
80 gb ssd
And still my browser (chrome) gets slow down and hangs for 2-3 secs and then suddenly load. And this happens to every tab.
Shall I increase my ram and if yes which ram and how much gb of ram
I am a heavy browser user, I use almost 40 to 50 tabs at a time.
Thanks in advance.
https://linustechtips.com/topic/289819-pc-for-heavy-browsing/
MOAR RAM!
Upgrade to 16 GB.
Desktop: i5 4670k, Z97-K, 16GB, MSI GTX 770, Evga 850G2, TT T31
Freenas Server: i3 4170, X10-SLL-F-O, Crucial 16GB UDIMM, 4x4TB WD Red, Evga 550GS, Fractal 804
Peripheral: K60, HyperX Cloud
Mobile: Nexus 6P
https://linustechtips.com/topic/289819-pc-for-heavy-browsing/#findComment-3935021
It might be the memory but 8GB should be fine even for that many tabs. I use a lot all the time and no problems with 8GB.
That is what I am unable to understand, I used to browse fine but now a days I don't know what is going on.
https://linustechtips.com/topic/289819-pc-for-heavy-browsing/#findComment-3935053
Have you cleared your cache recently? If not, that could be your issue. You need to completely wipe your Google Chrome cache. If you haven't, I'll give you a quick tip. @chitranjan
Downloading programs from CNet is not a good idea, as they will commonly include unwanted, and sometimes dangerous bloatware... The more you know.
https://linustechtips.com/topic/289819-pc-for-heavy-browsing/#findComment-3935114
The question is, are you using up your memory? If so then the answer should be obvious.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/289819-pc-for-heavy-browsing/#findComment-3935328
What's the limit after which adding ram to the system won't help browser.
Depends on your browsing habits, really there is no limit, the more RAM the more tabs you can have without it exploding.
pc specs: 4 function calculator / 8 digit lcd display / colored numeric and function buttons
https://linustechtips.com/topic/289819-pc-for-heavy-browsing/#findComment-3946318
But linus made a video where 64 gb ram was not utilized properly by many softwares.
Will chrome also do that or will it use all of that ram.
https://linustechtips.com/topic/289819-pc-for-heavy-browsing/#findComment-3951862
if its a 64-bit app then it probably will. i don't know if chrome does, but opera 64 does and waterfox does.
https://linustechtips.com/topic/289819-pc-for-heavy-browsing/#findComment-3954741
