Hey guys
I recently got a  Cooler Master Seidon 240M from a friend and I have no complaints about it except that the fans that came with it are very loud. I've been meaning to replace them for some time now but I don't know what kind of fans would be best suited for this to keep it quiet. I have the rad mounted in a pull configuration on the top of my NZXT H440. My friend swears on his Corsair fans but I also heard very good things about Cooler Master and Noctua.
If you can give me any recommendations I'd appreciate it.
Thanks in advance.
My build: CPU:  i5-4670K Mobo: ASRock Z87 Extreme4 RAM: Kingston Fury Red Series 16GB GPU: Asus GeForce GTX 970 STRIX Case: Corsair Obsidian 750D
https://linustechtips.com/topic/289315-silent-fans/
noctua and corsair both make very nice fans.
i <3 my af140's
just cuz im curious, is the seidon 240m the one that ships with the new silencio fans?
https://linustechtips.com/topic/289315-silent-fans/#findComment-3927852
Noctua fans with the included adapters.... I mean, I can barely hear a thing, and I have 5 of them sitting right next to me.
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
https://linustechtips.com/topic/289315-silent-fans/#findComment-3927855
I have Cougar Vortex fans in my wife's machine, and the airflow through the mesh baffle on the front of the HAF XB produces the only noise. If I removed the front panel from the case, I have to place my ear inches away to hear the fans.
They're the PWM 140's & normally spin about 900 RPM.
https://linustechtips.com/topic/289315-silent-fans/#findComment-3927885
Check out BeQuiet!
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/289315-silent-fans/#findComment-3927891
Scythe Gentle Typhoons if you can find them. I have the AP-14 versions myself.
Arc Midi R2 | Asus Maximus VII Hero | Intel i5 4690k | Asus GTX 970 Strix | Corsair H80 | Crucial M4 128gb | 8gb 1333 Mushkin Silverline | EVGA G2 750
Filko Ninja TKL Cherry MX Black | Mionix Naos | Fiio e10k | Edifier S330D | Sennheiser HD558 | Blue Snowball | Asus PA238QR | Samsung BX2250
https://linustechtips.com/topic/289315-silent-fans/#findComment-3927910
Thanks for all the replies. I have one more question: would it be quieter or less quiet to put two 140mm fans in the front of my case vs 3 120mm?
No they come with the Nepton I believe.
https://linustechtips.com/topic/289315-silent-fans/#findComment-3931886
bu-b-but the linus ad :S
it said ze silencio fens :c
https://linustechtips.com/topic/289315-silent-fans/#findComment-3932296
