So I am picking up another Asus 7770 2GB card to CF with my current Asus 7770 2GB card, so I was wondering, since it only takes one 6-pin PCI-E Cable can I use a dual 6 Pin PCI-E cable for both GPUs or should I run another PCI-E cable?
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/289195-do-i-need-another-pci-e-cable/
For neatness, i'd say run another one.
Main PC: Core i5 4670 | MSI Mpower Max z87 | G.Skill Ripjaws 2x4gb | Stock intel cooler | PNY GTX 770 2gb (hoping to upgrade) | Seagate 1tb 7200rpm | Corsair RM850 | Corsair Carbide Air 540 | PCCG custom sleeved black/yellow extensions | Corsair K70 Cherry MX Blue | Corsair M45 |
Phone: LG Nexus 5 | Headphones: Audio Technica ATH-PDG1, Shure SRH440 | Laptop: Asus 303la (i5 model, 1600x900 res) | Motorbikes: 2004 Sherco 290i, 2013 Husqvarna CR125 | Xbox one
You can use a dual cable or run two, they'll both work.
This is very, true, but i have OCD so i reckon that 2 would be easier to cable manage etc. @RevoltTrain , depends weather you care about messy cables or not, but your case doesn't have a window, so you probably don't mind if it's messy.
You should run another.
Any particular reason?
You should sell you 7770 and buy a better single gpu. 7770 cf is a terrible idea.
I only have $100 for a new GPU, and I can't be without a GPU to sell my current one, my CPU doesn't have an iGPU
It will work well enough, if you can get it cheap enough, but yes a sale and a single card will be more worthwhile/enjoyable.
Depends on whether you can go without the use of your computer. If you can't then there you go. If the game supports crossfire well then the 7770 will be an acceptable experience.
Potential power draw. I suppose it's only relevant in higher end cards, but I'd still recommend running another.
Please, just do this. Just to be sure, it's otherwise possible you fry the cable. Probably small chance, but still...
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
Do you know where I can buy another PCI-E cable for a CX750M?
Umm did you lost one? The psu comes with 2 pci-e wires...
Mine didn't, I contacted Corsair, but Corsair has horrible customer support
Well then it's probably easiest to go ghetto and use a 2x4-pin to 6-pin adapter. That should work fine. Normally it's shipped with the new gpu
