Project Dollar Help
As I ship my old parts away I need to start thinking of my new AMD build...
I'll make a build log for this once I start ordering the parts. I need this for 1440p-4k gaming and im starting to get into rendering and programming.You might say why no Intel or NVIDIA?I'm a AMD fanboy.
So I will not execept a Intel/NVIDIA build...
So is the build below worth it?The reason I didn't go with a 295X2 was simply because you can't add a water block later on.
Also don't criticize me on the PSU..I only care about the johnnyguru reveiw.
The watercooling parts because I already have them. Just need to find the AMD bracket for the CPU block...
PCPartPicker part list: http://pcpartpicker.com/p/QnLJP6
Price breakdown by merchant: http://pcpartpicker.com/p/QnLJP6/by_merchant/
CPU: AMD FX-9590 4.7GHz 8-Core OEM/Tray Processor  ($219.99 @ I don't know Where)
CPU Cooler: Cooler Master DK9-7E52A-0L-GP CPU Cooler  ($9.98 @ OutletPC)
Motherboard: Asus Sabertooth 990FX R2.0 ATX AM3+ Motherboard  ($175.98 @ OutletPC)
Memory: AMD RG2133 Gamer Series 16GB (4 x 4GB) DDR3-2133 Memory  ($193.98 @ Newegg)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  ($78.97 @ OutletPC)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($77.75 @ OutletPC)
Video Card: MSI Radeon R9 290X 4GB LIGHTNING Video Card (2-Way CrossFire)  ($329.99 @ Newegg)
Case: Corsair 750D ATX Full Tower Case  ($134.99 @ Micro Center)
Power Supply: Antec 1300W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($240.98 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Other: EK Supremacy Full Nickel Block
Other: EK Tubing,EK LED Lights,EK Drum Resivwater Thing
Other: Swiftech 380mm Radiator
Total: $1946.51
Generated by PCPartPicker 2015-01-11 15:38 EST-0500
https://linustechtips.com/topic/289099-project-dollar-help/
Just a reminder that your CPU is a bottleneck
However since you are adamant on AMD get the AMD SSD's. They are good
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/289099-project-dollar-help/#findComment-3924991
Please, Dont use the 9370...
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/289099-project-dollar-help/#findComment-3924992
This.
Get a 9590
/s
https://linustechtips.com/topic/289099-project-dollar-help/#findComment-3925021
Just dont get that CPU its ridiculous... Fanboy-ism can go too far you know. AM3+ is such an outdated platform it just does not belong in a high end build like this.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
https://linustechtips.com/topic/289099-project-dollar-help/#findComment-3925039
You know you can get waterblocks for the 295x2, plus if you really want an AMD build then the AMD SSDs would go really well with it.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/289099-project-dollar-help/#findComment-3925054
Don't think that 9370 is a bottleneck seen plenty of videos showing GPU load under 100% and everything running even better than on i7's, some people claim that it does bottleneck.... I don't even know anymore.
Read the links in my sig to see proof that it bottleneck (8320 @ 4.4/4.7 = 9370)
https://linustechtips.com/topic/289099-project-dollar-help/#findComment-3925083
Well I'm sorry but I trust Jay more :D I will read your post tho
For 4k gaming and rendering the 4790k, or 5820k KILL the 9370.
https://linustechtips.com/topic/289099-project-dollar-help/#findComment-3925205
Are you telling us that you got this sold?
You had an X99 build with a 5930x and 2x980s and you sold it for a 9590 and 290X build? Why did you even have that build in the first place? If you're so against Intel and Nvidia?
something smells a bit fishy....
I done been through a whole lot. Trial, tribulations, but I know God - Kendrick Lamar
I question your mother's upbringing if you don't like me - Action Bronson
You apocalyptic dingleberry - James 'Captain Slow' May
https://linustechtips.com/topic/289099-project-dollar-help/#findComment-3925550
So after first going a overkill build you directly step in another overkill build seriously what is wrong with you. Either you are full of shit and just keep us busy with your dream builds or you are just dum and don't wanna listen and waste money which is fine but instead of wasting it on PC's share it with the poor. Also just get a 4690k, Z97 board, GTX970, 8/16 Gb RAM, 550 or 750 Watt PSU depending on future upgrades, SSD+HDD and a nice case and go with it.
https://linustechtips.com/topic/289099-project-dollar-help/#findComment-3926067
