Hey LTT Forum!!
I m gonna host a lan party and everyone is bringing their desktops.
i will use my ITX pc (corsair rm650, r9 290 i5 4670k) and a monitor i have lying around.
Now my question is: can i use a power strip for my pc and my monitor and possibly another pc and monitor on the same power strip and what would happen if it would overload?
Thanks
JOhannes
My setup
CPU i7 4770K 4.8 ghz 1.4V Motherboard MSI G-45z87 RAM 32gb 1600mhz hyperx ram GPU 3x Gtx 780ti Windforce GHZ edition Case NZXT Phantom 820 Storage 64gb SSD and a 500GB HDD PSU corsair ax1200i Display(s) 3x Acer S231HL Cooling h105 8 corsair af 120
https://linustechtips.com/topic/289089-power-strip-lan-party/
Hey LTT Forum!!
Thanks
JOhannes
You could but just be contious of the power draw.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/289089-power-strip-lan-party/#findComment-3924825
Normal european socket with normal european power strip can theoretically handle 3600W which is a ton. so even if it can handle less you should still be fine with two systems.
https://linustechtips.com/topic/289089-power-strip-lan-party/#findComment-3924836
thanks guys
My setup
https://linustechtips.com/topic/289089-power-strip-lan-party/#findComment-3924918
