Do i really need a graphics card? Help
it will be in the future but for now i don't really have time cause of coursework and tests.. ergh
In that case, buy just the i5.
Then, when you get enough money, buy an R9 290 or GTX 970. I think you will be much happier with this as the end result. It will also allow you to spend more money on a better CPU and motherboard for overclocking.
PCPartPicker part list: http://uk.pcpartpicker.com/p/DWpjsY
Price breakdown by merchant: http://uk.pcpartpicker.com/p/DWpjsY/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor (£173.94 @ Aria PC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£25.44 @ Aria PC)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard (£101.91 @ Ebuyer)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory (£57.60 @ Kustom PCs)
Storage: Crucial M500 120GB 2.5" Solid State Drive (£46.84 @ Amazon UK)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£35.94 @ Aria PC)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply (£63.31 @ Amazon UK)
Other: PowerMac G5 (£0.99)
Total: £505.97
Generated by PCPartPicker 2015-01-10 00:41 GMT+0000
