Audio Help!
Go to solution Solved by minibois,
You changed it to default on Windows AND Skype?
Why is audio playing through my speakers even though i selected my headsets as default?
I wanna join a skype call with friend but their call keeps playing through my speakers even though i changed it to default device to play on
and videos plays audio perfectly on my headset
I'm using windows 8.1
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/287640-audio-help/
https://linustechtips.com/topic/287640-audio-help/#findComment-3906138
Fixed it! Thanks! :)
https://linustechtips.com/topic/287640-audio-help/#findComment-3906161
