bitcoin help
Go to solution Solved by Decon,
don't waste your money bro; bit coin mining really isn't worth it.  go burn your money some other way :/
Want a good game to play?  Check out Shadowrun: http://store.steampowered.com/app/300550/ (runs on literally any hardware)
another 12 core / 24 thread senpai...     (/. _ .)/     \(. _ .\)
https://linustechtips.com/topic/286736-bitcoin-help/#findComment-3892992
Why?
Are you doing this just for fun?
Because you're going to loose lots of money if you do.
https://linustechtips.com/topic/286736-bitcoin-help/#findComment-3892995
