Hello! I recently switched motherboards from the Asus M5A78L-M LX PLUS to the Gigabyte 990FXA-UD2 (mainly for the additional PCI slots). I have two hard drives, a Samsung 840 EVO 120GB SSD and a Western Digital Green 2TB Hard Drive. When I booted, first the computer tried to boot from a left over bootloader on the hard drive, some quick bios changes fixed that. Then, I found that the WD Green hard drive was not correctly setup so the OS on the SSD failed to mount it. After some digging, it appeared that it was plugged into the wrong SATA slot on the motherboard, after I corrected this, the entire hard drive was wiped and the data on the SSD was corrupted. The SSD is less than a month old and the hard drive is less than a year old with neither one having heavy use. I reformatted both drives and everything is working now. I also purchased all of the parts for a custom built NAS for backups. My question is, should I replace my WD Green hard drive?
https://linustechtips.com/topic/284198-should-i-replace-my-hard-drive/
if it works, no. ;)
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
Try using "hard disk sentinel" the free version is enough to get a rough idea if the hard drive has any issues, works for me.
Don't get how it can be plugged into the wrong sata port though, if your OS was installed on your SSD along with the proper boot loader, then the system should just either mount it as a different drive letter? Unless something more complex was set up?
Cartman - AMD Phenom II x6 1055T 3.1Ghz - 10GB Ram (Mwahahah) - 256GB Crucial MX100 Boot - 2TB WD Red - Gainward GTX 770 - Zalman Insanely Loud CNPS14X - Corsair 230T Orange
Stan - Intel Pentium G3320 - 8GB Ram - 128GB Intel 520 - Raid 1 6TB WD Reds - Bit Fenix Prodigy
Kenny - HP 14 Ultrabook (No name apperently) i3 4130 - 128GB Intel 520
I am using Linux, and I could not find a Linux version of Sentinel (it's also a commercial program which I generally try to avoid), Instead I used a Linux program called GSmartControl which reports the drive is in good condition. I have my OS setup to mount drives based on the sata port number.
