Please help me decide! (AMD vs. Intel build)
the i3 is just behind the fx 6300 in multithreaded apps. couse you see it has hyperthreading,its not a pentium. and in games its better.and after some years he can just put an i5 in the same motherboard,which is better than any amd cpu
Your sole opinion is not the only thing that matters. There is several arguments for and against the i3. The r7 265 is out of stock on happii.dk and i can't find it anywhere else
Here's a comparison. They are not the same CPUs (i3 4330 vs 6350 instead of i3 4160 vs 6300, but it's a close comparison)
In my opinion there is not a clear winner, but (i hate to say that) i think the 6300 is more futureproof.
He can buy the FX6300 and keep him for 4-5 years and he will only need to upgrade the GPU, which is a better solution than buying a new CPU in 2 years.
Also, i bet he wouldn't want to buy an 1150 i5, after 3-4 years, as an upgrade for his z97 mobo just like you wouldn't buy the i5 2600K if you had the i3 2100.
Anyway, that's just my opinion... I am not arguing with you. I just want to help rap1dcs. ![]()
