Best Mic for Commentaries? (And some voice overs)
OneManWolfPack5
The AT2020 and Yeti will both serve you well. Not sure about others
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
^^^^^^^ this
I'm that guy with the GPD Win.
Snowball or Yeti for sure. Audiotechnica makes some good stuff too
AT2020 if you want a plain and simple option (USB) but you want to be more advance (XLR) and have better audio quality just because, get a AT2035 with a scarlett 2i2. The AT2035 comes with a good stock mount. All you need to do is buy a mic arm xlr cable, and pop filter.
You must "Quote" to get my attention​.
 ~IBIubbleTea - 20/07/2014
They're all very good, you should look up reviews and tests on Youtube to figure out which sound you like the most, as no microphone sounds exactly the same, even same make and model microphones have slight differences (very small).
I'd go for the one that has the least annoying light on it. I know my Blue Snowball has a pretty annoying red light right on top.
EDIT: also Rode have a very good reputation in the mic business.
Edited by Lauen
Reviews: JBL J33i   M50s   SRH440   Soundmagic PL50
