Hi,
I am planning on building a PC some time in January, and i have been researching components and watch heaps of Linus videos.
This is my list of components from PCPartPicker.
http://pcpartpicker.com/user/Bloocookie1/saved/9Vsj4D
I am about to start my final year at school, and i am a digital art student. So my projects need lots of power to run. I will also be using this PC for gaming as well.
My current photography project consists of over 300 18MP raw images put together in photoshop, and all the systems i have tried on (even my teacher's) have failed quite miserably.
For one of them i had to leave my macbook pro retina running almost all day just for it to stack and get the pictures ready for processing in photoshop. Later in the year i have to be able to edit about 5, 30min(aprox.) videos for my IBDP group project. So i will mostly need to be able to (as seamlessly as possible) run Photoshop, Premiere Pro and After Effects, plus gaming (not at the same time obviously). My teacher had suggested i look into a 4K monitor, and i was initially looking at the Asus PB287Q but the was a TN monitor.
P.S. I might change the keyboard and mouse to a different option before purchasing.
https://linustechtips.com/topic/281176-first-pc-build-help/
Hi,
I have come up with 2 different builds, with about $1k difference. Please look over them both and advise on any changes that might be better.
I have attached the file with the components as well.
PS. the monitor i think i am going to buy is the new Acer B326HK 4K IPS Monitor, and i will may change the keyboard and mouse.
Option 1:
Intel® Core™ i7-4790K
ASUS Z97-DELUXE (NFC & WLC)
ASUS PB287Q 28-Inch Screen LED-Lit 4K Monitor
Gigabyte GeForce GTX 980 G1 Gaming
Corsair Vengeance LPX 32GB DDR4 DRAM 2666MHz
Mad Catz R.A.T.7
Corsair Raptor K70 Gaming Keyboard
Cooler Master V850 - 850W Power Supply
Samsung Electronics 850 Pro-Series 2.5" 512GB
Seagate Barracuda 2 TB HDD SATA 6 Gb/s
Corsair Hydro Series H110 280 mm
Corsair Graphite Series 780T
Option 2:
Intel Core i7-5960X
Asus X99 Deluxe
2xASUS GTX980
16GB Corsair Vengeance LPX
Mad Catz R.A.T.7
Corsair Raptor K50 Gaming Keyboard
1000W NZXT Hale90 V2
2x 512GB Crucial MX100
4TB Western Digital Black
NZXT Kraken X61
What are you planning to do with the computer? Cuz spending that much just to game isn't really smart unless you're doing some intense video editing.
Main Rig
Case: NZXT H440 White | CPU: Intel Core i5-4690K @5.2GHz | CPU Cooler: Corsair H80i Hydro Series | Motherboard: MSI Z97S Krait Edition | RAM: HyperX Fury White & Black Series 16GB (4x4GB) OC to 2133MHz | Graphics Card: Zotac GeForce GTX 980 Ti ArcticStorm | SSD: Intel 730 Series 480GB & Samsung 840 256GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA 750W Supernova G2 80+ Gold | Display: BenQ XL2420G & Samsung S20D300 | Headset: Corsair 1500 | Mouse: Logitech G700S | Keyboard: Corsair Vengeance K70 Silver RED LED
 XENON Build:
Intel Xeon E3-1230 V2 @3.3GHz | Intel DZ68BC | Corsair Dominator Platinum 2x4GB 1866MHz | Kingston HyperX 3k 240GB | MSI GeForce GTX 680 | Fractal Design Define R4 Titanium Grey | Seasonic 520W 80+ Platinum Fanless
Office Build:
Case: Fractal Focus G White | CPU: i5-8600K | CPU Cooler: Cooler Master Hyper 212 Evo | Motherboard: MSI Z370-A PRO | RAM: Corsair LPX 16GB-2666 | GPU: MSI GTX 1060 6GB GAMING X | SSD: Kingston A400 240GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA BT 450W+ Bronze
Phone
iPhone XS Max 512GB Gold
https://linustechtips.com/topic/281176-first-pc-build-help/#findComment-3817599
We need to know what you're plans are for the computer.
Also, if you could make the lists in PCPartPicker and display them with the BBCode option it's much easier to look at. :)
Just at first glance, you could save quite a bit of money in some areas, and some parts should be swapped out for more reliable units like your PSU.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/281176-first-pc-build-help/#findComment-3817680
Thanks Dizmo,
I have edited my original post with the pcpartpicker link. and a explanation on my (most likely overall) usage for the system.
https://linustechtips.com/topic/281176-first-pc-build-help/#findComment-3820321
Hi,
Great build for editing!
The Seagate 2TB 7200rpm is good hdd... but me and my friend bought new pc's with that hdd and had problems with 100% disk usage...Well I fixed mine but he is still having problems with freezing ect. So I don't know what to tell you.. be cerful
To be an expert is to know more about less.
  • 2014 Build --> FX 8350 4.7GHz {} ASRock Fatal1ty 990FX Killer {} Reference GTX 980 4GB {} 2x4GB 1866MHz HyperX {} Seagate 2TB 7200rpm {} 840 EVO 120GB {} XFX PRO850W {} Noctua NH D14 {} Fractal Define R4 White Windowed
  • 2018 Build --> Ryzen 7 2700X {} ASRock Fatal1ty X470 Gaming K4 {} Gigabyte RTX 2070 8GB {} 2x8GB HX Fury 3200MHz {} Toshiba P300 2TB {} Kingston 480GB A1000 {} Corsair RM750W {} Enermax LIQMAX II 240 {} Fractal Focus G
  • 2021 Build --> Ryzen 9 5900X {} ASUS ROG Strix X570-F GAMING {} ASUS GeForce RTX 3080Ti ROG STRIX OC {} Gigabyte AORUS RGB DDR4 32GB {} Kingston KC2500 M.2 2280 NVMe 2TB {} Seasonic FOCUS GX-1000 {} ASUS ROG Ryujin 240 AIO {} NYXT H710i
  • 2026 Build --> Ryzen 9 9950X3D {} ASUS ROG CROSSHAIR X870E HERO {} ASUS GeForce RTX 5090 32GB ASTRAL LC {} G.Skill TridentZ Royal Neo RGB Silver DDR5 CL28 6000MHz 2x16GB {} Samsung SSD 4TB 9100 PRO M.2 {} Seasonic 1600W PRIME TX Noctua Edition {} Fractal Lumen S36 V2 RGB 360mm AIO {} Fractal Design North XL Charcoal
https://linustechtips.com/topic/281176-first-pc-build-help/#findComment-3820413
Thanks Dizmo,
Good job, and welcome to the forum :)
Another thing you might want to include is your budget.
I don't know much about the kind of work you're doing so I can't really suggest anything. It sounds like it might benefit from RAM, so 64gb on an X99 platform might be just what you're looking for?
@WoodenMarker might have a better idea for a build like this.
https://linustechtips.com/topic/281176-first-pc-build-help/#findComment-3820611
Not surprised about the terrible systems you're using at school--pretty common for tech like that to be outdated and improperly optimized. *cough* pairing $2500 Cintiqs with $500 systems
Can you link us to where you're actually shopping? Pricing is a big factor when it comes to proper recommendations.
Regarding the system:
There's no point getting such overkill aftermarket cooling if you're not oc'ing. That and you need a K series cpu to oc.
Dominator Platinums are a waste of money. Ram is ram and there are plenty of other similar kits that are immensely cheaper.
The psu is overkill unless you're planning on triple sli for some reason.
Why such a large case? Why a 4K display instead of a properly color calibrated one?
https://linustechtips.com/topic/281176-first-pc-build-help/#findComment-3826775
Do you have any suggestions on an alternative? or do you think WD is a better option to look into?
https://linustechtips.com/topic/281176-first-pc-build-help/#findComment-3827197
The CPU is a K series.
Can you advise me on another RAM at 32GB DDR3 that would be a better option?
I have just for the moment selected the V850 PSU suggest or the sake of it. but once i have decided on all my parts, then i will see for an appropriate PSU for the final wattage required.
I wanted this case for its aesthetic reason and that its big enough that if i want to upgrade something at a later date, i will for sure have enough space to do so.
I want a 4k display as my main monitor since i work with very high-def images and 4k video as well. and when i want to check on the colours, i can just drag it across onto my smaller 1080p display which (i think) has great colour accuracy.
Oh yeah i will be purchasing the parts from amazon, seeing that none of the PC stores here in singapore have the necessary parts to build a PC. And it is more expensive buy here even after getting a rough estimate price from amazon then converting from USD to SGD.
https://linustechtips.com/topic/281176-first-pc-build-help/#findComment-3827234
Huh.. it wasn't before.
Brand of ram doesn't really matter. Just get the cheapest kit that fits your needs. What other programs are you using?
The 780T is ridiculous large if you don't plan to fill it with lots of water cooling.
What 1080p display do you have?
https://linustechtips.com/topic/281176-first-pc-build-help/#findComment-3827316
Well for being safe I would go with WD HDD for example WD Green, I don't see a reason for going WD Black bec you have a 512GB SSD so that extra speed from the WD black is not necessary.
Oh I'm back so my friend fixed it. Truns out Win 8.1 was using the whole allocated virtual memory from the HDD so he went to options and changed the value and everything is fine now.
So yeah that is the fix, your choice now
https://linustechtips.com/topic/281176-first-pc-build-help/#findComment-3827472
