I have a h80i. The led on the block are stuck on a purple and wont go fully red
by any chance are you on win 8.1?
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/280694-h80i-led-wont-change/#findComment-3811237
yes
the Corsair link program dont like win 8.1
it is a known error
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/280694-h80i-led-wont-change/#findComment-3815246
