I am deciding between the Asus Strix or the EVGA ACX 2.0 970. Now the thing with EVGA is that they sell 3 differents 970 with different clockspeed, am I better off getting the cheaper one and overclocking it or pick the priciest one because it wouls techniquely have a better bining? Also the Asus one is really tempting because it only require 1 8pins to power the card, witch would make it easier for future SLI. (My OCZ 700w PSU only have 2 8pins PCIE power connector)
Witch one would be the best between these card? Noise is not really a concern as my case is already filled with corsair fan. THANKS!
Case : Corsiar Air 540 CPU : Intel i5 8600k GPU : Asus Nvidia 970 DirectCUII RAM : 16gb DDR4 MB : ASUS Prime z370-p PSU : OCZ Modxtreme 700w SSD : Samsung 840 EVO 250gb
https://linustechtips.com/topic/277568-difference-between-different-evga-970/
Oh and if you have any other suggestion, feel free to post it. My system is blue... I like blue
The Strix & ACX cards aren't binned, the only 970 to my knowledge that is binned right now is the Gigabyte G1.
I'd say get the strix since you mentioned it'd be easier to get a second one down the road.
(Is the Gigabyte G1 970 out of the runnings for you? it has a blue LED)
get the normal acx 2.0
you might have problems finding waterblocks for the others if you ever want to watercool.
http://www.ekwb.com/news/554/19/EK-releases-ASUS-GTX-970-Strix-Full-Cover-water-block/
Easy as pie ;)
I am not really a water cooling king of guy. Maybe in a distant future where I finished university and all my school depts are paid off.
Yeah seems nice, but I am not a fan of the non platted copper pieces on the cooler :(
I think I will go for the strix :P, It is at 410$ in canada, not bad if you ask me.
Comfirmed, Asus strix and a shield portable are on the way! The shield is actually the main reason I switched to the green team.
Thanks a lot guys!
Oh man, not another Strix....
"Rawr XD"
Care to elaborate on your thoughts? haha xD
Easy as pie ;)
i was talking about the evga cards.
Maybe go with priciest evga one, each different EVGA 970 includes a different version of the ACX 2.0 cooler. The priciest one has the best.
i7-5820K | ASUS X99-A | Corsair DDR4 LPX 16 GB | MSI GTX 970 Gaming | Corsair 750D | WD Black 1 TB | MX100 256 GB | EVGA SuperNOVA 750 Watt | ASUS VG248QE | Corsair H105 | K70 MX blues non-RGB | M95 | H1500 | Windows 8.1 64-bit
