gtx 970 70% fan speed for long period of time while gaming?
Werdna
is it fine? im afraid it will break or something. noise is not my issue. I just want to know if running high fan speeds will do any harm to my components :o
What I have learned when I asked if I could have my fan speed at 100% for long period of time.
They said that it will shorten life time but most likely not break.
I would say that 60-70% while gaming is common.
Just done have it like that when you are only using web browser or something.
So no it would probably not break and to me it looks fine 70% is not that high. But the 970 should most likely not need it since it and 980 is so strong and power efficient.
PC  Specs 2022:
  • CPU
    AMD Ryzen R9 5900x @ 5.1GHz - Auto OC
  • Curve Optimizer Magnitude: -20
  • Motherboard
    ASUS ROG STRIX x570-F Gaming
  • RAM
                                        Kingston Fury 32GB DDR4 3200MHz 16x2GB
  • GPU
    MSI 3070 8GB Ventus 2x OC
  • Case
    LIAN LI LANCOOL MESH II Mesh RGB Black
  • Storage
    Kingston NV1 2TB M.2. NVMe
  • PSU
    Seasonic Focus GX 850w
  • Display(s)
    MSI OPTIX MAG 251RX IPS 240hz & ASUS MG248Q Vertical 144hz & Dell 60hz
  • Cooling
    NZXT Kraken x73 360mm
  • Keyboard
    Tt eSports Meka G1
  • Mouse
    Logitech G Pro Wireless
  • Operating System
    -Windows 10 Professional 64bit
One thing is you won't be able to use a Graphic card more than 5 years. I'm running my EVGA GTX 560 ti overclocked and 90% or 100% fan speed for 2 years now and it works perfect.
Considering power efficiency of maxwell architecture in 970, you may not need that much of fan speed
What are your GPU tempratures while having 90-100 fan speed?
i7-5820K | ASUS X99-A | Corsair DDR4 LPX 16 GB | MSI GTX 970 Gaming | Corsair 750D | WD Black 1 TB | MX100 256 GB | EVGA SuperNOVA 750 Watt | ASUS VG248QE | Corsair H105 | K70 MX blues non-RGB | M95 | H1500 | Windows 8.1 64-bit
I used to run both of my cards @ 100%, now I put them around 80-85 as my cards can barley get to 65 degrees. Most people upgrade before the card has a chance to die.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
