Hello all!
I have put these parts together, Can anyone check them out?
Motherboard: Gigabyte GA-Z97P-D3  Edited
CPU: Intel Core i5 4690K
CPU Cooler: Scythe Mugen 4 SCMG-4000 Edited
RAM: Crucial Ballistix 8GB DDR3 1866Mhz Edited
Hard Drive: Just a 1000gb hard drive nothing special
GPU: MSI GTX 970 Gaming 4G GDDR5 Edited
PSU: Corsair VS Series VS650
Case: Corsair Carbide SPEC-03 RED
If you have any suggestions that I could change, Please reply!
Thanks for your time.
https://linustechtips.com/topic/276657-help-me-with-this-build-please/
If you're going with an unlocked i5 CPU, buy a Z97 board... you're wasting money if you don't
I done been through a whole lot. Trial, tribulations, but I know God - Kendrick Lamar
I question your mother's upbringing if you don't like me - Action Bronson
You apocalyptic dingleberry - James 'Captain Slow' May
-You will need a "Z" chipset on your mainboard: z87. To overclock your processor.
-It wouldn´t be that bad if you choose a littler higher clocked ram, 1866mhz.
-I would go for the MSI/Gigabyte design GTX970
YOU GOT SOMETHIN AGAINST THE STRIX BRO? YOU WANNA FIGHT?
#STRIXMASTERRACE #STRIXORGTFO #YOUAINTRIGHT
-Z board z87/z97 (I think you need to update the BIOS on the z87 board for it to work with the Haswell refresh CPUs)
-Find a better cooler. Some single tower aircooler from noctua or be quiet will do a great job of keeping your CPU cool and being quiet.
