He had his foot on the clutch? AHAHHA
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/276237-brake/#findComment-3750466
This is exactly why i don't like being a passenger.
https://linustechtips.com/topic/276237-brake/#findComment-3750470
I dont get it how can anyone that drive more than 1 year confuse brake/clutch/gas
There are so many videos on liveleak where person hits gas instead of brake and causes accident.
ikr surely you could tell after a few seconds
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/276237-brake/#findComment-3750482
you underestimate the power of stupidity.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/276237-brake/#findComment-3750508
Probably haven't driven a manual or not used to it. People used to driving manuals sometimes mash the brake on automatics because they are used to heavy clutches.
But you have to be pretty ignorant to not realize there are three pedals.
i agree
My Setup :P
https://linustechtips.com/topic/276237-brake/#findComment-3750985
Guys can someone tell me that using clutch way often I mean everytime is bad? Cuz I always mass clutch when I am driving a car.
are you unbanned?
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/276237-brake/#findComment-3752011
