Hey all of you guys out there!
I want some LED fans in my system, but I don't know which fans to buy... So I want fo ask you. I want : nice looking fan with nice looking LEDs (multiple colours or red LEDs), they should not be very noisy and they should have some pretty nice RPM too :D
Thanks all of you for your answers !!!
https://linustechtips.com/topic/27594-nice-led-fans/
BIT FENIX SPECTRE PROS! NUFF SAID. EVERYTHING ELSE DOES NOT MATTER. :))For me its a good balance of good looks and LED Lights
The have 120mm, 140mm, 200mm and 230mm Fans with Red, Blue and Green and white LEDS. :)
If you want just fans. You can never go wrong with Noctua's NF-F12's or Silverstones AP. :)
If you want high RPM's Gentle Typhoons would be great!
If you want great Static pressures I'd go with Noise Blocker E-loops. :)
CPU: i5 -2400 Cooler: Noctua NH-L12 Mobo: Fatal1ty Z68 Pro Gen3 Memory: Corsair Vengeance 8gb 1600mhz SSD: Samsung 840 120gb HDD: WD 3TB Green, Seagate Barracuda 1TB GPU: Asus GTX 760 Direct CU II (future SLI) Sound card: Xonar Phoebus PSU: Corsair RM series 750 watts Case: Aerocool Mechatron Fans: Bit Fenix Spectre Pros
Monitor:Samsung SyncMaster SA950, Philips Blade 234CLSpeakers: Logitech z506 Headset: Razer Tiamat 7.1 KB: Blackwidow Ultimate Stealth edition Mouse: Ouroburos Mouse pad: Golaithus Extended Speed edition Gamepad: Orbweaver Controllers: Wireless Xbox 360 Controller, Razer Hydra
System: Razer Edge Mouse: Razer Orochi Mouse pad: Razer Vespula Controlers: Razer Sabertooth (2 pcs.) Headset: Razer Blackshark Speakers: Razer Ferox What can I say, I'm a huge fan of Razer.  :D
https://linustechtips.com/topic/27594-nice-led-fans/#findComment-350827
Yeah I saw the Bit Fenix Spectre Pros and they look sweeeet :D, also my friend has two of them and he says that they work like a charm...
https://linustechtips.com/topic/27594-nice-led-fans/#findComment-351028
http://www.cougar-world.com/products/fans.html
Well there is some new Cougar LED fans on the market now, i want some, there listed on NCIX but says non in stock, and so i am trying to look where i can buy them from.
however they do look awesome.
http://www.aerocool.us/accessory.htm
also aerocool make nice red led fans, i have some Carbon fibre look red led fans and love them.
hope that helps
got to love Asus components
https://linustechtips.com/topic/27594-nice-led-fans/#findComment-355814
