anyone know any good high pressure fans i can replace the h100i stock ones with?
Main Rig
CPU-
AMD FX 8350 | CPU Cooler- CM hyper 212 Evo | GPU- Radeon HD 7970 | RAM- G.SKill Ripjawz X 2x4 | Storage- 1TB WD Black | 128gb Plextor Ms5 | Case- BitFenix Shinobi   | Motherboard- Gigabyte AM3+ UD3 | PSU- Rosewill hive 750 watt
 Media PC
CPU- A10-5800k | GPU- Onboard | RAM- Ripjaws X 4Gb | Storage- Seagate 1TB | Case- Bitfenix Prodigy M | Motherboard- MSI A75M-E35 | PSU- Antec 350W Basiq
https://linustechtips.com/topic/27534-pressure-fans/
Noctua NF-F12 PWM great silent fans and very good static pressure if you don't mind the color.
CPU: Intel i5 3570k 4.2GHz with Corsair H100 RAM: Corsair 16GB (4x4) SSD: Samsung 840 120GB HDD: Seagate Barracuda 1TB GPU: Strix GTX 1080
PSU: OCZ 650W CASE: Fractal Define R5
https://pcpartpicker.com/user/MelchiorVester/saved/#view=RKNXsY
https://linustechtips.com/topic/27534-pressure-fans/#findComment-349956
Noctua NF-F12s, they are silent and powerful. Bought them yesterday, once you go Noctua, you never go back!
G4MING RIG - CPU: i7 5930K  Cooling: Custom Loop  MOBO: Asus Rampage V Extreme  GPU: EVGA 980 Ti GTX Classified  RAM: Corsair Dominator Platinum DDR4 16 GB  SSD: Samsung 840 Pro  PSU: be quiet! Dark Power Pro 11 850W Platinum Certified  Sound: Asus Xonar Essence STX II  CASE: Phanteks Enthoo Primo  PERIPHERALS: Das Keyboard Ultimate 4, Logitech G502 Proteus Core, Sennheiser G4ME One, B&W MM-1, ROG SWIFT
Macbook Pro Retina 15" 2012CPU: i7 2,7 GHz  GPU: GT 650M,  RAM: 16GB,  SSD: 512GB
https://linustechtips.com/topic/27534-pressure-fans/#findComment-352330
yea i have 2 NF-F12s on my h100i they push as much air as he stock fans at near silent operation, i literally have to be within 3 inches of the fan to hear it. I've also heard noiseblocker makes incredible fans for rads though I've never had experience with noiseblockers. Singularity Computers however does use them at lot in his build logs so yea...
https://linustechtips.com/topic/27534-pressure-fans/#findComment-354078
noctua nf-f12, have 4 of em, had in push/pull on my h100i, but the ones on top weren't directly against the rad so it made kinda an annoying "wind" noise. Took them off the top, left the others in pull.  DEAD quiet now.
Edit: now I use one as an exhaust fan, and have it hooked up to the h100i and controlled by my graphics card temp. Works really nice.
https://linustechtips.com/topic/27534-pressure-fans/#findComment-355052
I'm also thinking of replacing my H100i stock fans with NF-F12s,
Are they significantly quieter at the same rpm? That's the only current problem I have with my stock H100i fans... they are so loud; I have to use quiet mode. :/
CPU: Intel 2700k (4.7) MOBO: Asus P8Z77-V DELUXE GPU: Sapphire Vapor-X R9 290X RAM: 16GB Corsair Vengence (1866) CPU Cooler: Corsair H100i w/ 2x Noctua NF-F12 Storage: 256GB Samsung 830 Pro SSD (Boot), 64GB Crucial M4 (SSD Cache), 1TB WD Black Cavier, 2TB Hitachi, 2.5TB Buffalo Sound Card: Xonar Essence STX Case: Corsair Graphite 600t w/ full acrylic side PSU: Corsair HX750 (individually sleeved)
Peripherals: Filco Keyboard (Brown) Razer Deathadder, Sennheiser HD595, Zalman ZM-MIC1, Steelseries Qck Mass mousepad.
Pics of my Rig
https://linustechtips.com/topic/27534-pressure-fans/#findComment-357674
BOOM! Delta "Mega Fast" 120mm x 38mm Fan - 252 CF
FX8120 @ 5.0GHz | Sabertooth 990FX | Patriot Viper Xtreme 8GB @ 2133MHz | Powercolor HD7950 @ 1300/1800 | Bitfenix Shinobi XL Modded | Corsair AX850 | Mushkin 120GB & Seagate 2TB | Bitfenix Recon | 5X SP120 PE | 6X Yate Loon 120mm HS
Koolance 200 Res | 2X Koolance 360 Rads | Danger Den CPX Pro | EK 7950 Block | Koolance CPU Block | Bitspower & XSPC Fittings
Green Machine
https://linustechtips.com/topic/27534-pressure-fans/#findComment-357688
