Best CPU for 970
Solved by 79wjd,
It is if you enjoy games that run better on strong cores than weak ones.
What do you mean? I didn't get the sentence
An FX6300 will still be good enough in MOST games (thus buying an i5 isn't really a worthwhile upgrade). So, while it's not an ideal pairing with a GTX970, it will be enough to get 60fps in most games at 1080p and pretty much all games at 1440p. And 144hz/4k isn't going to be happening on a single 970 (although 4k would be fine on an FX6300).
