Air flow logic confict.
I have a bit of an airflow logic conflict.
I have a Switch 810 and have notice it is drawing in dust from the cracks. That obviously means low air pressure inside the case. My problem is I have literally no fans to turn around to negate this low air pressure.
Red: Fans
Brown: Radiators
Orange: Water cooling tubing
What would you make the fans?
My current setup:
1 140mm OUT
2 120mm OUT
3 120mm OUT
4 140mm OUT
5 140mm OUT
6 120mm IN
7 120mm IN
8 140mm IN
9 140mm IN
I was thinking about flipping FAN 1, however, that might just make air loop between 1 and 2 and it might just make the system hotter.
Do you think I should flip one of the fans?
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/2737-air-flow-logic-confict/
You could try for a while with everything taking air in and see how the system fares both with temps and dust?
This isn't like a Lanboy Air. I don't think it would have enough holes in it to be able to push out 9 fans worth of air. The fans and therefor the airflow would slow down. I am thinking of adding a bit of cardboard between the Fan 1 and 2 exhaust side to see how it goes.
https://linustechtips.com/topic/2737-air-flow-logic-confict/#findComment-36248
I've done a pretty rough setup in a physics sandbox with all the fan speeds the same. You can see roughly that with fan 1 reversed you're going to have a loop and I also just then after reading your idea with the bit of cardboard and tested both inside and out and you still get the exhaust from 2 being drawn in by 1.
Though take these with a grain of salt because they can't factor in what you've got on the side panel if you do..
https://linustechtips.com/topic/2737-air-flow-logic-confict/#findComment-36252
Are your temps bordering on acceptability? Otherwise just lower exhaust RPMs, or remove #1.
Alternatively, flip it all. Flip everything.
Alternalternatively, what's going on in your drive bays? Could you use three of those for a fan mount?
https://linustechtips.com/topic/2737-air-flow-logic-confict/#findComment-36291
I might just remove #1 or lower the speeds. I will try to adjust fan curves on the fans to see if it helps as all my new fans will be PWM.
https://linustechtips.com/topic/2737-air-flow-logic-confict/#findComment-36297
