CPU Running Slow
Go to solution Solved by JakeD,
I fixed it now, thanks for the help guys.
Hey guys, I have an i7-3820 3.6 GHz but for some reason its currently running at 1.19 GHz and I don't know why. I fucked around in the bios to turn off any eco/power saving options and its still running at 1.19 GHz. Anybody have any ideas? I left a CPU-Z screenshot so you can have a look.
https://linustechtips.com/topic/270313-cpu-running-slow/
Its because you're not using it much. It downlocks at idle to save evergy and produce less heat.
When you put it under load it will go to 3.6GHz.
https://linustechtips.com/topic/270313-cpu-running-slow/#findComment-3668273
I reset the cmos and the multiplier is still at 12-6
what board is this? are you using the latest UEFI?
https://linustechtips.com/topic/270313-cpu-running-slow/#findComment-3668986
the board im using is msi x79a-gd45
update to the latest uefi on the product page for that board, then do a full cmos reset and let us know if that worked
https://linustechtips.com/topic/270313-cpu-running-slow/#findComment-3669018
Aren't core clock calculated by multiplying the core speed and multiplier and then dividing it by the number of cores?
CPU: 5820K GPU: Gigabyte G1 970 RAM: 16 GB Crucial Ballistix Mobo: EVGA m-ATX Cooler: Corsair H100i Case: Xigmatek Aquila PSU: NZXT 700W Monitors: 2 x Wasabi Mango (1440p)
Do you play Go/Baduk/Weiqi? I am AGA 4D.
"We do not shop by brand, we shop by what delivers us the best performance, features and quality for the money we're spending" - Linus (Techquickie)
https://linustechtips.com/topic/270313-cpu-running-slow/#findComment-3669300
